VTEC Pressure switch on s300
Old Sep 5, 2014 | 01:49 PM
JHipps's Avatar
Default VTEC Pressure switch on s300
Okay so this past week I took my car to be dyno tuned. We found out that my VTEC was not engaging at all and that I had to look into it. So when i got home I went through my parameters and noticed that my VTEC oil pressure switch was not checked off. Did my tuner maybe forget to check it off and thats why it was not engaging? I looked at the help link on s300 and it said that if the computer is jdm or motor is jdm to disable it but nothing on my car is JDM. Its a B18A1 Block with a B16 Head. The ecu is P06 (37820-P06-A02). Or is the ecu JDM?
Old Sep 5, 2014 | 02:10 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: VTEC Pressure switch on s300
There are too many variables to take into account. Low VTEC fluid, low oil pressure, LS-VTEC not done right, wiring is wrong, calibration file is set up wrong, etc... If your tuner sucks that could be an issue too. Stop being lazy and check some stuff out like he told you to do.
Old Sep 5, 2014 | 02:21 PM
JHipps's Avatar
Nobody here is lazy..I just got the tune done a couple days ago, I have other things going on, can't always just work on the car. Why wouldn't I start diagnosing with something as simple as the click of a button then uploading to the s300?
Old Sep 5, 2014 | 03:32 PM
Spunkster's Avatar
That is a non-vtec ECU, has it been prepared for VTEC?
Old Sep 5, 2014 | 03:59 PM
mtber's Avatar
A 37820-P06-A02 ecu is a non-vtec ecu.
You will either need the proper vtec hardware added to the ecu for vtec to function correctly or you will need to use an alternate vtec output in the Smanager using a relay & disable vtec pressure switch etc.
Old Sep 5, 2014 | 05:25 PM
JHipps's Avatar
Thank you for letting me know. The previous owner had a VTEC motor. Not sure if it was setup. Is there a way for me to check or something to look for on the board to know its setup properly for VTEC?
Old Sep 5, 2014 | 06:10 PM
JHipps's Avatar
Here are a few pictures
Old Sep 5, 2014 | 06:11 PM
DO IT ON ALL FOURS
Click on the picture in this link for a larger picture...
http://support.moates.net/vtec-conversion/
Old Sep 5, 2014 | 06:15 PM
DO IT ON ALL FOURS
We posted at same time... your board is prepped for VTEC. Check to make sure none of the solder joints look bad or burnt.
Old Sep 5, 2014 | 06:39 PM
JHipps's Avatar
I did they all look good. So the VTEC pressure switch being disabled in the parameters on my s300 calibration has nothing to do with my vtec not engaging?
Old Sep 5, 2014 | 07:33 PM
DO IT ON ALL FOURS
Some JDM engines didn't come with a VTEC Pressure Switch so the way you get around that without throwing a code is to manually do it with wires or select the box to disable the VTP switch. Obviously doing it in SManager is MUCH easier. So as long as you have it set for the ECU to disable the switch then it will not stop VTEC from activating.
You can take a datalog to verify that the VTS is coming on in the sensor window as well just to verify that side of things. Another way would be to use a DMM or test bulb on the VTEC pin.
Old Sep 6, 2014 | 03:57 AM
7rrivera7's Avatar
Not saying it's the problem but at postion C60 there should be a 1uf tantalum capacitor and the pic shows an electrolytic.
Old Sep 8, 2014 | 09:28 PM
JHipps's Avatar
Well i did a datalog and the VTP is on but the VTS sensor does not come on. Also have a check engine light that comes on on after driving the car. Have to check code tomorrow
Old Sep 8, 2014 | 09:41 PM
JHipps's Avatar
Is that supposed to be off at all times or does it only come on when im around 5k rpm when vtec is supposed to engage?
Old Sep 9, 2014 | 10:07 AM
JHipps's Avatar
Would Code 11 come on after driving for about 10 minutes? Idk if I am reading the check engine light correct but thats what im seeing.
Old Sep 9, 2014 | 04:02 PM
DO IT ON ALL FOURS
Just to be sure: In the SManager you can see CEL codes by clicking on the tab. A window will pop up and say what the code is in the box. IIRC the tab will even have a red exclamation point by it when a code is thrown.
Old Sep 9, 2014 | 05:27 PM
JHipps's Avatar
Yeah I saw the little red exclamation mark. When I clicked on the tab though, nothing came up. I am pretty sure now it is 11. Tried a few times. I've found that 11 is Bad ECM but also found that it could be engine overheating?
Old Sep 9, 2014 | 09:25 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Code 11 is a "Hondata only" code for overheating. The default setting is 212' F and this will limit certain functions of the car once reached. Do you have a functioning speedometer (VSS) ???
Old Sep 10, 2014 | 06:04 PM
JHipps's Avatar
Yes i do
Old Sep 16, 2014 | 08:06 PM
VegasInvasion's Avatar
I'm Huge In Japan
if you're actually overheating, Vtec will not engage. Don't trust the gauge in your cluster, it's never right on Hondas. Post a calibration and a datalog.
teamworxek9
Honda Civic (2001 - 2005)
Jul 29, 2007 04:27 PM
Takumi Fujiwara
Jul 23, 2006 09:18 PM
98HB
Mar 16, 2003 02:16 PM
GummyBeng
Feb 17, 2003 10:11 AM
