P28 D16Y8 HELP
I've recently decided to install a chipped p28 on a stock d16y8. However the car runs terribly. It accelerates slow, it wastes a lot more fuel and the car shakes a lot. It does have a y8 basemap.
Before I installed it, I've been told I needed a new throttle position sensor. With that being said, i told my tuner exactly this and he said once I replace the tps, the car should work fine. Is this true? Because I've also read that p28s don't run well with stock y8s. Any help would be appreciated. as a side note, my 2step sounds a lot different than my friends 2step (he however drives a dc5) any reason why?
I still dont know why people are consistently brain washed on P28 ECUs when they dont need a 28 map.
Guess another one learns the hard way. Your "tuner" is just there to take your money. Trust me.
It actually runs a bit better now with the p28. I switched back to the stock one and it ran even worse. I'm in the process of cleaning the iacv and will see if it will run back to normal
SovXietday
64
Jun 11, 2019 06:42 PM
ngarover
Feb 8, 2015 08:04 AM
