s300 no upload!
Old Jun 14, 2014 | 09:13 AM
DC2Shawn's Avatar
Icon3 s300 no upload!
Hi, I went to plug in my p72 hondata s300 and went to upload a calibration and it fails everytime.
I tried my buddys p72 s300, and his uploads and everything perfect.
I got his friend, who also did his s300 and local peoples ecu's to install my s300.
I did some research on the problem, and some people say its the ecu socketing.
Now i dont wanna take it back to him because this was a last year some time, and had a couple plans changed with the car i was gonna use the ecu in, and am just getting to use it now so he'd probably blame me because i wasnt ASAP w/ the return.
What should i be looking for? I'm gonna be opening my friends ecu and my ecu for a side by side comparison of a known working s300.
Thanks.
Old Jun 14, 2014 | 05:49 PM
DC2Shawn's Avatar
Default Re: s300 no upload!
saving myself the trouble and ordering a new ecu s300 socketed.
Old Jun 14, 2014 | 11:28 PM
MOTORVATIONS's Avatar
Move your s300 board into your friends ECU and see if you can upload... if so, then you are correct in stating that your ecu/socketing is the problem. If you still have the same problem of upload failure, your issue is the s300 board. This will isolate your problem before you order a new ECU.
Old Jun 15, 2014 | 03:13 AM
wshuculd's Avatar
Did you register it before you tried uploading anything? Is the light green
Old Jun 15, 2014 | 04:10 AM
Markov1's Avatar
Yes, you better go for the new socket and save yourself a lot of troubles...
Good luck
nick91civicsi
Engine Management and Tuning
Oct 25, 2009 03:27 PM
wrXtian
Apr 13, 2003 04:29 PM
Frosty_spl
Nov 18, 2001 05:46 PM
