Default D16A vtec-e (2stage) in need for base map.
Old May 18, 2014 | 09:27 AM
RACEPAK's Avatar
hey guys,
can anyone please tell me which ecu goes with a d16a vtec-e? or maybe somone have a bin for it?
just checked the engine and it has 300PSI compression :O
thanks
Old May 18, 2014 | 12:13 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: Default D16A vtec-e (2stage) in need for base map.
D16A is the ZC P29 engine, but that isn't Vtec-e. You may want to check the head code and make sure it's not P2J, that means someone probably swapped a Y5 P2N head on a ZC block, in which case you're just gonna have to tune it because nothing will match up to that. P08 might be a good start though depending on your injectors.
Old May 18, 2014 | 12:41 PM
RACEPAK's Avatar
yup, head says P2J-5
Old May 25, 2014 | 11:39 AM
I'm Huge In Japan
well that's depressing.
builtsinglecam
Jul 23, 2009 04:02 PM
White91EF
Dec 31, 2006 11:31 PM
shbrown
Nov 7, 2005 04:14 PM
MestizoRacer310
May 30, 2004 11:06 PM
Eg692Si
May 17, 2003 10:00 AM
