How do I set dizzy timming with s300
Old Apr 27, 2014 | 06:05 PM
$MIKE$'s Avatar
Default How do I set dizzy timming with s300
Hey guys I'm running s300 with coil on plug cpr
I am having Ignition problems from the cpr and thought it may be my dizzy so I swaped it with another and now I need to know how to set the dizzy timming.
Is there a way to open s manager and set it threw there.
Or do I need to jump the service connector and get timing light. Will the timing light still work with no plug wires?
Old Apr 27, 2014 | 06:21 PM
1158's Avatar
Default Re: How do I set dizzy timming with s300
Use SManager. You have to have the car running and Hondata connected to have the set timing option available from the drop down menu (under the Online drop down).
You can lock the timing then you set it like normal.
Old Apr 28, 2014 | 03:09 AM
$MIKE$'s Avatar
What do I clip my timing light around I don't have spark plug cables
Old Apr 28, 2014 | 03:21 AM
1158's Avatar
Just clip it on the coil pack wiring for #1, it works just like with plug wires. I did it when I swapped to the CPR.
raverx3m
Apr 9, 2012 09:15 AM
turbo sol
Apr 8, 2009 02:07 PM
jchrm80
Dec 22, 2007 05:14 PM
conorm
Mar 6, 2002 03:47 PM
