Question about making basemap
Old Aug 5, 2014 | 06:21 PM
black97civic's Avatar
Default Question about making basemap
I have a 97 civic ex that I just finished building an engine for. Its a b18c1 block with pr3 head. B18c1 transmission. I'm using neptune demon in a po6 ecu. 11.5mm wiseco pistons 9:1 w/turbo setup. 900ccFIC injectors.
My question is when I'm making the basemap which ecu type and ecu basemap do I choose. I tried p30 for each setting and entered 900cc injectors and I couldn't start it without increasing te fuel quite a bit. Is that the correct choice?
Old Aug 5, 2014 | 06:45 PM
Default Re: Question about making basemap
Also if you have to increase fuel say 35% to start the car and get it idling at 14.7 do you increase the whole map 35%?
Old Aug 6, 2014 | 01:55 PM
114 views and nobody knows? I have searched for literally hours and find the same info over and over but nothing specific!!
Old Aug 6, 2014 | 02:06 PM
HRTuning's Avatar
Adjust the overall trim if it's very rich or lean, then tune your idle area, and the rest from there.
Old Aug 7, 2014 | 07:42 AM
2000CTRSi's Avatar
The "Fuel trim" can be used to manipulate the fueling for the whole rom.
A lot of times the when changing the injector size, it makes it about 20-20% leaner than needed. Its completely normal.
Find out how lean... if 30% then put 30 in the overall trim and leave the 2 maps alone.
highlight the whole map and add 30% on both cams is another way to do it... however it will manipulate the duty cycle reading...
Old Aug 7, 2014 | 08:15 AM
scottdh20's Avatar
adjust offsets to get a 14.7 idle, not the fuel map
Old Aug 8, 2014 | 06:14 PM
VegasInvasion's Avatar
I'm Huge In Japan
1.) use the P72 basemap
2.) use the ID1000cc battery offsets
3.) SUBTRACT 10-15% from your cranking and post-start values. Don't know why, but this usually solves starting issues.
4.) add 3* ignition advance to your idle range before you start adjusting the fuel trim.
5.) adjusting fuel trim should clean up the rest of it.
Fnix
May 17, 2012 03:04 PM
benclimber17
Apr 22, 2008 06:05 PM
keebler65
Jul 6, 2003 07:27 PM
mr2
Nov 13, 2001 11:33 AM
