Bad ECU?
Old May 23, 2014 | 06:59 AM
theiazn's Avatar
Default Bad ECU?
I recently had my car manual converted and swapped to a F20B and finally tested out my p28 that got chipped and uses a crime basemap. My car shakes a lot when it's around 1200 on the tach and redlines at around 3500. I borrowed a friend's P28 with a B16 basemap and everything ran fine, does anyone know what could be wrong?
Old May 23, 2014 | 11:23 AM
92cxturbo's Avatar
Default Re: Bad ECU?
Sounds like limp mode, is the cel(check engine light) on? Maybe the other ecu has something disabled that your ecu does not.
Have you tried contacting the person/company that chipped the ecu?
Old May 26, 2014 | 06:17 AM
theiazn's Avatar
Problem solved, it was a bad base map on the chip.
allums34
Feb 20, 2011 09:10 AM
JeffBro
Engine Management and Tuning
11
Jan 5, 2011 04:20 AM
DraginTeg93
Mar 17, 2007 04:16 PM
b16nonoy
Feb 19, 2007 01:10 AM
