SDASH app hondata s300 for android
Old Jun 12, 2014 | 10:14 AM
949's Avatar
949
Default SDASH app hondata s300 for android
hey guys I just saw this advertised and thought to look at it closer. so far I am saying "its about time". as a s300 hondata user I have always wanted to have a gauge hooked up to the s300. I was wondering when someone would make this.
I have looked all over the internet for more info and there isn't too much so far from actual users. it seem to be much faster than tradition gauges that read from the obd2 port. this seems to be a huge plus.
what is it?
its a program you download into your android. the android can be your cell phone or a tablet.
it uses the live information from your ecu s300 and sends the info to your android unit via your cable you already have with a simple adapter you can get at fry's electronic or ebay.
SDash is digital customizable dashboard to display live data coming from an Hondata® s300 plug-in module.
See what your car is doing in real time using your android device, without the need of a computer!
*** Build your own dashboard using more than 60 available analog gauges, digital gauges and widgets! ***
Supported sensors:
• Engine speed (RPM)
• Vehicle speed sensor / Speedometer (VSS)
• Gear
• Manifold absolute pressure (MAP)
• Throttle position sensor (TPS)
• Injector duration (INJ)
• Injector duty cycle (DUTY)
• Ignition advance (IGN)
• Intake air temperature (IAT)
• Engine coolant temperature (ECT)
• Oxygen sensor voltage (O2)
• Fuel mixture (lambda or AFR - Gasoline, E85 or E100)
• Short term fuel trim (S.TRIM)
• Long term fuel trim (L.TRIM)
• Knock level (K Level)
• Battery voltage (BAT)
• Rev limiter (REVL)
• Launch retard (Lnch.R)
• Launch cut (Lnch.C)
• Air conditioning switch (ACSW)
• VTEC pressure switch (VTP)
• Service connector switch (SCS)
• Fuel pump (Fuel)
• Secondary Intake Runners (IAB)
• Power steering pressure (PSP)
• Purge control valve (PCS)
• Check Engine Light (CEL)
This application requires additional hardware in order to work:
• ECU with Hondata® s300v1 or s300v2 installed.
• USB-OTG Compatible android device
• USB Cable to connect to your device.
cost?
about $10.00
personally im willing to pay that for this interesting program but it needs to work flawlessly.
is there anyone else here who has it and can give a detailed review on SDASH?
I would like to hear more before I pull the trigger on buy a tablet just for this whole setup.
Old Jun 13, 2014 | 04:30 AM
OMG THE GOGGLES's Avatar
Default Re: SDASH app hondata s300 for android
http://www.hondata.com/mobile.html
There is also Dash command etc
Old Jun 13, 2014 | 04:57 AM
mtber's Avatar
Old Jun 13, 2014 | 08:12 AM
949's Avatar
949
I read that SDASH needs a cable for it to work.
when did the V3 of hondata come out? I upgraded to the V2 not that long ago.
they are super underhanded when they didn't even tell me about the newer version 3. hondata should have at least mentioned it to buyers.
Old Jun 13, 2014 | 03:25 PM
mtber's Avatar
You are correct SDash is a different APP I thought you were referring to Hondata's Free APP called Hondata Mobile.
Details on Sdash can be found on http://sdashapp.com/
I assumed you were referring to Hondata Mobile App (ios and android):
http://hondata.com/mobile.html
Hondata s300v3 was released in April and can be purchased via authorized dealers:
http://phearable.net/engine-computer...data-s300.html
Old Jun 13, 2014 | 07:40 PM
sdashapp's Avatar
@949 there are some videos on youtube that you can check out:
I saw in another thread (https://honda-tech.com/forums/showpo...&postcount=392) that @speedjunkie_g35 was going to try it.
Old Jun 14, 2014 | 11:32 PM
949's Avatar
949
ok so which one is better? hondata app or the sdash?
Old Jun 15, 2014 | 09:02 AM
sdashapp's Avatar
Hondata mobile works only on Hondata s300v3 and FlashPro thru Bluetooth
SDash works only on s300 thru the USB Cable.
On SDash you can customize the gauges that you want to see, I don't know about hondata mobile.
Old Jul 8, 2014 | 10:14 PM
sdashapp's Avatar
There is available a free version now:
https://play.google.com/store/apps/d...xco.lite.sdash
The paid version support more widgets and sensors, but with the free version you can see it working. Hope you like it.
Best Regards
Rafael.
Old Jul 8, 2014 | 10:28 PM
Black R's Avatar
25 Year Member
idevice compatible too?
Old Jul 8, 2014 | 11:02 PM
sdashapp's Avatar
Android only.
Old Jul 9, 2014 | 04:34 AM
m4xwellmurd3r's Avatar
Best Regards
Rafael.
This is awesome! Only reason why I havent bought it is cause I wanted to test it out first.
Do you think youll one day be able to record datalogs through the app?
Old Jul 9, 2014 | 06:08 PM
sdashapp's Avatar
Hope you like it @m4xwellmurd3r!
Yes it will.
Old Jul 10, 2014 | 03:29 AM
Sweet. Then I wont have to lug my laptop eith me when I need to do extended datalog sessions
Old Jul 10, 2014 | 04:35 AM
Freemananana's Avatar
I think iDevices have some kinks in the Bluetooth that prohibits stuff like this. Torque is a common OBD2 Bluetooth app for stuff like this.
S300 doesn't have onboard automatic datalogging?
Old Jul 10, 2014 | 05:08 AM
sdashapp's Avatar
Do you use smanager or other software to analyze the data?
Old Jul 10, 2014 | 02:03 PM
sdashapp's Avatar
S300 do have onboard data log, but the problem is the memory restriction.
OBD2 apps like torque work only with the latest s300v3 board, for the v1 and v2 we're stick to the USB. IDevices do have restrictions on USB communication.
Regards
Old Jul 11, 2014 | 12:41 AM
Yep, I use smanager when I have to do any datalogging. I like seeing what happens in realtime and record it for later use. The onboard function just doesnt hold enough data for me.
(Usually go out driving for 30-60 minutes to check for any off spots, etc)
Old Jul 30, 2014 | 12:14 PM
ShinsenTuner's Avatar
No Jodas
NICE! This answers all of my doubts on whether or not to invest in gauges for my project car. I will be downloading this app in conjunction of purchasing a tablet for a heads up display as well. THANK YOU!
Also, just downloaded the free app to try it out. Not too bad, going to connect it to S300 when the adapter comes in. Really excited for this!!
Old Jul 31, 2014 | 08:40 PM
sdashapp's Avatar
SDash now can retrieve and show the CEL code from s300.
Old Jul 31, 2014 | 08:46 PM
VegasInvasion's Avatar
I'm Huge In Japan
This all looks like an advertisement.
Personally I'll stick to the TunerView, so I can still look at **** on my phone while I'm driving.
Old Jul 31, 2014 | 08:48 PM
sdashapp's Avatar
Old Aug 4, 2014 | 09:13 PM
949's Avatar
949
what is the adapter part number we need from the electronic stores?
Old Aug 4, 2014 | 09:28 PM
sdashapp's Avatar
You can ask for a "Micro USB-OTG adapter".
http://www.amazon.com/s/field-keywor...%20otg%20micro
http://www.ebay.com/sch/i.html?&_nkw=micro+usb+otg
Old Aug 4, 2014 | 10:04 PM
949's Avatar
949
my next question is.
what if I reformat my cell phone or sell my phone?
how does the paid key code work when that happens?
