xenocron obd0 tuning?
Old Jun 8, 2014 | 05:02 PM
br8crumb's Avatar
Default xenocron obd0 tuning?
just curious if anybody has bought a chipped ecu off them for a obd0 ecu. basically just give them specifics and they formulate a base map with turbo edit.
also is there anybody locally like south jersey/philly area who tunes with turbo edit?
being used for a n/a nothing crazy, just debating obd0 or upgrading obd1 thanks
Old Jun 9, 2014 | 04:28 AM
Muckman's Avatar
Moderator in Chief
Default Re: xenocron obd0 tuning?
I believe Turbo Edit is officially dead. That doesn't mean you cant use it but its no longer supported or updated. I would upgrade to OBD1 just to use a current tuning platform like Neptune or Hondata.
Old Jun 9, 2014 | 06:58 AM
br8crumb's Avatar
im not exactly sure where xenocron is located, but it says there in the tristate area. also when you click tuning/dyno it does list turbo edit as a option but to call first.
basically just tossing in cams and a bigger manifold with ur basic i/h/e. the base map alone would probably be fine but idk
Old Jun 9, 2014 | 09:43 AM
xenocron's Avatar
Im agreeing with Brian here.
Its not dead but its more of a DIY scenario and we really shy away from "TUNING" with OBD0 ECUs and software as the time involved is not worth the end result in my opinion anymore.
Converting to OBD1 is a much better idea and way to spend your hard earned $$$
- Chris
Old Jun 10, 2014 | 08:14 AM
br8crumb's Avatar
i understand upgrading to obd1 for any and all tuning options, but i personally dont see the point in this case. oem ecu can handle the i/h/e but im just looking for a little extra something to help out with the cams while retaining stock sensors/compression etc.
xenocron, would the basemap just be a oem turbo edit map for a pr4? or would it have changes to help stabilize anything listed which can be fine tuned later?
and my friend over at hiboost can street tune turbo edit for me in a few weeks so even though its out dated it shouldnt take too long to just adjust idle and a/f
Old Jun 10, 2014 | 08:15 AM
br8crumb's Avatar
"shouldnt take too long" implies a few hours lol
Old Jun 10, 2014 | 10:21 AM
xenocron's Avatar
I use an old version of TurboEdit for basemaps, using "NG61" or "NG60" code revision. You can scale the fuel maps for a different size injector, but datalogging is a lot of fun, and dialing in everything perfectly is very difficult without great datalogging.
Old Jun 10, 2014 | 02:44 PM
br8crumb's Avatar
so you wouldnt guesstimate any a/f increase on stock compression with say a stage 2 cam when doing the base map?
never really touched tuning before but iv convinced myself, not sure why, that when putting a base map on any cam/compression change is estimated so the car would start and run ok, which can be fine tuned to what the engine likes after.
and i would prefer to stay obd0 for the rest of the year while i start piecing together a new project, so soz if my questions seem noob
Old Jun 13, 2014 | 09:13 AM
Tippyman's Avatar
All you need to go obd1 is a conversion harness and a dizzy iirc. The o2 sensor can be deleted in the ecu.
Old Jun 14, 2014 | 06:57 PM
br8crumb's Avatar
little more then just like a rywire obd0-obd1 kit and distrib. and i dont have 02s and dont plan on using any. the cars obd0 theres no need for um
Old Jun 29, 2014 | 04:51 PM
VegasInvasion's Avatar
I'm Huge In Japan
I still get some solid tunes out of Turboedit. Some people hate jumper harnesses, or just have a boner for saying "OBD0". It doesn't have all the support or features of OBD1, but on the same token it doesn't have nearly as many bugs as Crome does =D
If you're not going for more than 250hp then TE will do the job just fine.
kraquepype
Apr 18, 2018 01:39 PM
mrpaccmann
Engine Management and Tuning
Apr 15, 2010 03:58 PM
pokmijn
Apr 22, 2008 01:04 PM
raeanin
Dec 24, 2004 10:53 PM
iHave2Cams
Mar 9, 2004 05:59 PM
