Chip pins about to break!
Old Sep 28, 2014 | 08:20 AM
Kid-jdm-teggy's Avatar
Default Chip pins about to break!
Hi my ecu went bad so I was swapping my chip to another ecu but when i removed the chip, one of the pin is about to break off, what should i do?
Old Sep 28, 2014 | 01:25 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Chip pins about to break!
Put it in a chip burner and copy it to a new chip.
(Vague direct answer based on direct question without detail about EMS.)
To MODs - I think it should be a standard thing or else face lock to post EMS and what version of Software AND Hardware when threads are made. It gets really old begging the OP for relevant information. Actually, this should be a requirement in all relevant sub-forums.
Old Sep 28, 2014 | 01:35 PM
Muckman's Avatar
Moderator in Chief
I agree but I could put it in the FAQ and they wouldn't read it either. I think your first answer was adequate.
Old Oct 7, 2014 | 07:49 PM
VegasInvasion's Avatar
I'm Huge In Japan
If you're in a pinch you can solder a wire from a resistor across the leg to reinforce it. I used a chip like that for 3 months before I remembered to change it
WeB
Engine Management and Tuning
Jan 19, 2010 11:17 AM
BUDtoker
Nov 6, 2007 06:24 PM
dkrex001
11
Sep 12, 2006 11:03 AM
BoostedD15B7
Mar 2, 2004 09:29 AM
InfamousRS
May 9, 2002 12:01 AM
