need ecu pins
Old Nov 20, 2009 | 07:24 PM
jdm95's Avatar
Default need ecu pins
Im trying to find a place to buy some spare female ecu pin connectors for a P72. Searched and found a place but not sure of the correct size. If someone has a link or a place i could call to order the correct ones i would appreciate it.
Old Nov 20, 2009 | 07:49 PM
H&AIMPORTS's Avatar
Default Re: need ecu pins
give me a call i can help you out or message me
H&A IMPORTS
brian 360-628-3766
Old Nov 20, 2009 | 08:06 PM
jdm95's Avatar
Cool. I searched in this forum as well as many others and just couldnt find the right info. Got a link to one place that sells them but no one seems to know the correct ones and theres about a hundred sizes to choose from LOL!!
If anyone knows should post it up would be good to have the info for anyone else looking in the future. Oh yeah pm'd you back.
Old Nov 20, 2009 | 08:11 PM
jdm95's Avatar
Also i read up on hooking up the MAC boost solinoid i have to my neptune RTP and it said to hook one wire to a power source and the other to pin A11 on the ecu. My question being is there anyone else that has a neptune and has done this. Also i thought there was already something on pin A11 or does it just make that a output now after having the Neptune RTP installed. Im really new at this so just want to make sure i understand correctly and i think the MAC solinoid operates at 31hz. but if anyone knows for sure let me know please. Thanks for any info posted up appreciate it.
Old Nov 21, 2009 | 06:07 PM
jonbar87's Avatar
pages 5 & 6
*edit* my bad, thought you needed pin outs lol. disregard the attached .pdf.
File Type: pdf
Old Nov 22, 2009 | 04:18 PM
jdm95's Avatar
Its cool, if anyone does have any info hooking up the mac solinoid to the neptune RTP ecu let me know i think its pin A11 but not completely sure.
Old Nov 22, 2009 | 06:39 PM
xenocron's Avatar
you need to add the ecu PWM components first...the activate boost control in the software and wire one side of the solenoid to a11 and the other side to switched 12v
i have pins if you need to purchase
Old Nov 22, 2009 | 08:28 PM
jdm95's Avatar
Thanks for the info xenocron, pm'd you also.
Old Jun 17, 2010 | 10:55 AM
GhettoBizzle's Avatar
Do these have a part number??
BIG T
Honda CR-V & Element
Jan 24, 2018 10:07 PM
DieMaster
Oct 22, 2005 03:31 PM
