Code 22
Old Nov 30, 2009 | 04:29 AM
Killer4Sho's Avatar
Default Code 22
I own a Integra type R dc2 now i am having a serious issue with this. If i stay in vtec for just about 6 seconds or more it throws a check light with the code in the title. Researched and it says that it is the Vtec pressure valve but at no point does the vtec shut off.. it simply throws the checklight and draws back the car kinda like its in limp mode.. i know this is not a mechanical issue because when i plug up my friends chipped computer with an ectune chip.. the car runs fine check light never comes on. Now i have discovered that my chipped computer is a Po6 and i was wondering if that could be a contributing factor or if it may even be a situation with the conversion harness. Was just wondering if anyone has ever experienced any problem like this because i kno the Po6 is actually a non-vtec ecu.
Thanks H-T
Old Nov 30, 2009 | 08:52 AM
HRTuning's Avatar
Default Re: Code 22
The ECU was probably converted to VTEC. As long as you're sure your oil pressure is remaining at a safe level you can disable the pressure switch input and you won't get the code anymore.
Old Nov 30, 2009 | 06:30 PM
Killer4Sho's Avatar
Default Re: Code 22
Thanx.. I actually got the conversion harness modified to bypass the the valve so the check light wouldn't come on.
Old Nov 30, 2009 | 09:07 PM
HRTuning's Avatar
Default Re: Code 22
That works too.
racereaper7
Aug 14, 2007 08:56 AM
tmanrose2007
Mar 27, 2007 08:38 AM
aleminx
Feb 18, 2006 07:25 AM
davejj40
Aug 30, 2004 01:29 PM
allmtrSI
Apr 29, 2003 05:13 AM
