P72 on a type r
Old Nov 14, 2009 | 10:43 PM
integraty95's Avatar
Default P72 on a type r
OK so I've searched everywhere and found information about having a p73 ecu on a gsr but what about a p72 ecu on a type r motor? i know that it wont run to the best of its ability but I'm putting in a motor tomorrow and i haven't found p73 yet. i have a p28 but i need to get a basemap on there first. i would only be using it for maybe a week tops and was wondering if it would cause a lot of harm to the motor? thanks in advance for the help.
Old Nov 15, 2009 | 02:11 AM
mtber's Avatar
Default Re: P72 on a type r
The engine will start & run on a p72 ecu.
I wouldn't recommend using the p72 other then to move the car around at partial throttle. The p72 engine has less compression & makes less power which means the map on the ecu outputs less fuel then a p73 engine would need at wide open throttle etc.
Old Nov 15, 2009 | 07:37 AM
ok. yeah im not going to be ragging on it, it would only be a quick substitution until i can get a basemap on the hondata or find a p73 ecu. but if it will at least run semi decent for a day or two then thats fine. thanks for the quick response.
Old Nov 15, 2009 | 10:25 AM
DDTECH's Avatar
why hondata? ..
Old Nov 15, 2009 | 07:56 PM
personal choice and it's easier to find someone to tune it up here. why should i not go with hondata??
that_sick_eg
Engine Management and Tuning
10
Feb 8, 2011 08:49 AM
.I.Need.Money.
Feb 23, 2007 04:04 PM
JDM95lude
Oct 6, 2006 12:36 PM
mark_is_gay
Aug 14, 2005 05:20 PM
Easyslider01
Jun 30, 2005 05:33 PM
