jumper harness question
Old Dec 5, 2009 | 10:12 AM
Keeper1343's Avatar
Default jumper harness question
I have a jumper harness i bought from a friend and im not sure if somethings wrong with it.
I plugged in two different ECU's and they don't let the fuel pump turn on. Then i put the stock ecu in and it fires right up. What pins should i look for on the jumper harness. I already looked at the fuel relay pins and they are correct... Maybe there are some other pins i should check??? Maybe the ECU isn't turning on? Some one please point me in the direction. Thankss.
Old Dec 6, 2009 | 08:48 PM
mtber's Avatar
Default Re: jumper harness question
Did you try another obd1 ecu to see if the issue was related to the ecu ?
Old Dec 7, 2009 | 01:32 AM
GhostAccord's Avatar
Is there a solid CEL when you try the OBD1 ECU?
Old Dec 7, 2009 | 06:51 AM
Keeper1343's Avatar
i tried two different ECU's and both have no power it seems.
Old Dec 7, 2009 | 07:00 AM
White Smoke's Avatar
i my honda
Global Mod
What make, model, and year is your car?
Old Dec 19, 2009 | 10:54 AM
xzodiackillerx's Avatar
fuel pump is in two diff places depending on the year and if you have a teg or civ
red96turbols
18
Oct 26, 2025 03:45 PM
TerpPL908
Jun 1, 2009 06:04 PM
jeffruby
Mar 19, 2006 06:30 PM
tuan...
Jan 4, 2004 08:07 PM
