S300 Tunning Problems
Old Nov 25, 2009 | 12:05 PM
hottopic58's Avatar
Default S300 Tunning Problems
I had a base tune in my new s300 when I got it and it was great but I was trying to tune on it and I couldn't find the base tune that it was. All i could find was the new calibrations. So I louded a stock h22 w/ 450cc base tune and it wouldn't even idle. I had to try and work with it all day just to get it to run at all. So once you loud a base tune of any other kind and don't have the other one saved some how it's gone for good????? All I can do is use a new calibration and go from their?? I want my base tune back what can I do??? Please help!!!!
Old Nov 25, 2009 | 12:07 PM
HRTuning's Avatar
Default Re: S300 Tunning Problems
It should have a download calibration option, unless they removed that because of all of the problems in the past.
Old Nov 25, 2009 | 09:59 PM
hottopic58's Avatar
I think I tried something like that and I said not to and I had already loaded the other tune. Do that mean the one it came with is gone for good??
Old Nov 26, 2009 | 06:46 AM
HRTuning's Avatar
If you can't download it then get the base tune from whoever originally put it up there.
Old Nov 26, 2009 | 08:26 AM
hottopic58's Avatar
I'm trying... They haven't answered back yet. But I hope they have it and can give it to me.
hottopic58's Avatar
Happy Thanksgiving Bump!!!
Old Nov 26, 2009 | 08:37 AM
HRTuning's Avatar
No doubt. Happy Thanksgiving.
Old Nov 26, 2009 | 09:18 AM
IN VTEC's Avatar
If you didn't pull off the calibration and save it on your laptop prior to loading a new one into the ROM, then it's gone.
Old Nov 29, 2009 | 05:06 PM
andrewd_89's Avatar
its not hard to tune on the s300, I find it quite fun actually...if you can't get it to idle make sure you know what: size injectors you have, what MAP sensor you have, your TPS is calibrated, and you have a wideband to accurately see your AFR and you have it correctly installed to your ECU say D10 ELD. And finally make sure once you know all these to check that it is correctly logged in your parameters. If you have any type of question someone has already asked it on the Hondata forum you just need to find it.... I went from 8 lbs of boost with 550cc injectors with a crome chip to 17lbs of boost on 1000cc injectors with a s300 in a weekend. Smanager is very user friendly you just have to introduce yourself to it and get to know it better
kraquepype
Engine Management and Tuning
Nov 16, 2018 09:30 PM
turbohatch96y7
Mar 2, 2010 09:36 AM
zach1288
Jan 19, 2009 03:33 PM
vtec-adykt
Mar 26, 2005 08:47 AM
C-Murdock
Mar 31, 2003 06:56 PM
