car falls on face
Old Nov 7, 2009 | 07:18 PM
lsvtechatch92's Avatar
Default car falls on face
ok I have s300 and am not throwing any codes car has a friends tune on it just to make sure everything is right we have very similar setups. The problem is at 2500 rpms is the car won't go past that it's like it powers down but comes back to life ones it gets back to 1500 rpms? Any ideas
Old Nov 8, 2009 | 12:33 AM
HYBRIDWORKS's Avatar
Default Re: car falls on face
can be ignition related, firing order, bad distributor coil and or igniter. does it happen in neutral?
can you hook up a laptop and verify if the load sensors are working. how does A/F look when its happening?
Old Nov 8, 2009 | 09:20 AM
Its a brand new distributor... the a/f look fine and i can and will hook up a lap top.... it does not happen in neutral or when i press the clutch in
Old Nov 9, 2009 | 10:17 AM
RC000E's Avatar
So, your running a wideband and when the car begins to bog there is no change....that's what your saying? Negative.
If the motor revs fine with no load, but bogs under load then it's either in the tune, ignition or fuel system related. Sounds pretty general right...well, without more specific troubleshooting and facts on your part that's all anyone can tell you aside from rambling random guesses off.
HYBRIDWORKS...your new little business there is violating Honda-Tech user agreement rules. Your sig is not allowed.
Blk00EJ8
Apr 28, 2007 01:27 PM
rdssk8rcs1
Oct 24, 2006 04:13 PM
Tru_Hybrid
Nov 6, 2003 06:44 AM
mingchi96
Dec 21, 2002 01:40 PM
SIK IN DA HED
Nov 13, 2002 01:30 PM
