SMOKEY
Old Oct 3, 2009 | 10:52 AM
E.D.S's Avatar
New User
Default SMOKEY
ANY SUGGESSTIONS ON HOW TO CURE A SMOKEY VTECH WITH OUT CHANGING PISTON RINGS???
Old Oct 5, 2009 | 07:17 AM
Top Ramen's Avatar
Default Re: SMOKEY
You should move this to the 'all motor' forum.
Are you sure the problem is the rings? Might be valve stem seals. Do a leak down.
Either way, there is no real cure without opening up the motor.
92db2gs-r
Jan 8, 2011 11:15 PM
Kensai
Oct 6, 2009 01:55 PM
EK FLY
Jul 1, 2007 02:52 PM
Chuji
Aug 19, 2003 02:06 PM
