Blown Headgasket?
Old Nov 7, 2009 | 03:59 PM
SoL_ger's Avatar
Default Blown Headgasket?
How do I know if i have blown my headgasket or not? Last night, my top hose on my radiator exploded and coolent was spewing out. I replaced the hose and put new coolant but my thermostat is bouncing up and down from H to the MIDDLE to halfway between C and Middle and now its chillin bewteen MIDDLE and H. Help me thanks..
Old Nov 7, 2009 | 04:19 PM
stevenDAtegra's Avatar
Default Re: Blown Headgasket?
Do you have coolant in your reservoir and has coolant ever been pushed into it? You can get a kit to test your headgasket that will check to see if there is a combustion leak.
You can try this out
http://www.arrowheadradiator.com/hea..._leak_test.htm
Have you replaced the thermostat ever or the water pump? Does hot air come out of the heater?
Old Nov 7, 2009 | 08:54 PM
PyroProblem's Avatar
Or do a compression and/or leakdown test...
Old Nov 8, 2009 | 12:40 AM
HYBRIDWORKS's Avatar
give me a call monday. Ask for Anthony, since were in town i think we can help.
Old Nov 8, 2009 | 10:30 PM
SoL_ger's Avatar
thanks for the help, i found the problem.
Old Nov 10, 2009 | 02:58 PM
Care to share?
Old Nov 10, 2009 | 03:12 PM
SoL_ger's Avatar
Originally Posted by PyroProblem
Care to share?
i was leaking coolant from my radiator and it was dry as the sahara
prodjay10
Honda Civic (2001 - 2005)
May 27, 2015 09:23 AM
SeanK325
Jun 22, 2010 02:52 PM
Cyber ITR
Sep 25, 2007 03:47 PM
b00sted4dr
Oct 12, 2006 10:19 PM
Accorddrver
Jun 29, 2004 06:25 PM
