speed limiter on a pr3 ecu
Old Dec 9, 2009 | 09:50 AM
crxsi361's Avatar
Default speed limiter on a pr3 ecu
i got a 1st gen jdm b16 with a pr3 ecu it came with and i tried topping it out and it stopped me at 115 anyone know why i still had all of 5th to go
Old Dec 9, 2009 | 11:01 AM
teamjdm239's Avatar
Default Re: speed limiter on a pr3 ecu
its a b16. it tops out at 115 anyways, so they put a limiter on it. ;P, haha jk. its a stock computer, and they usually put the speed limiter on the b16 pretty low.
Old Dec 9, 2009 | 11:30 AM
crxsi361's Avatar
yeah but i would think since i paid all that money it wouldnt have one
Old Dec 9, 2009 | 11:33 AM
HRTuning's Avatar
The stock ECU has a speed limiter. Regardless of what you paid, if you didn't order a modified ECU, that's what you get. Get it modified.......
Old Dec 9, 2009 | 11:44 AM
crxsi361's Avatar
where can i get it modified
Old Dec 9, 2009 | 01:22 PM
blasterman87's Avatar
what i wanna know is why do you need to go over 115?? you cant do that in 1/4 mile on a stock b16 not even close actually and doing 115 on a highway is, well not to bright.
Old Dec 9, 2009 | 04:37 PM
crxsi361's Avatar
cause i am planning on boosting it and whats the point if i cant hit past 115
Old Dec 9, 2009 | 04:48 PM
if its a jdm b16 tranny then you shouldnt be able to go much faster than 115 in 5th gear at 8k.. if your going 115 in 4th then you got ripped off
Old Dec 9, 2009 | 06:43 PM
HRTuning's Avatar
You'd have to have it tuned to boost on it anyway. In which case they'll remove the speed limiter.
Old Dec 10, 2009 | 11:02 AM
crxsi361's Avatar
ok and why would i have gotten ripped off if i can hit 115 in fourth that should be good shouldnt it
Old Dec 10, 2009 | 11:05 AM
teamjdm239's Avatar
what he means, is its probably not a b16 trans. the gearing on a b16 would not let u go 115 in 4th. youd be way to high in rpms.
Old Dec 11, 2009 | 09:47 AM
crxsi361's Avatar
what type of tranny would you recommend i get then
"NastIE Built"
Jun 21, 2007 06:55 AM
Deetz
Dec 30, 2005 04:32 PM
89EF9
Dec 2, 2002 12:41 PM
ef civic
Mar 20, 2002 04:18 AM
