p30 on a SOHC??
Old Oct 29, 2009 | 07:04 PM
j.packsb's Avatar
Default p30 on a SOHC??
i jus bought a p30 ecu and the guy told me that when i get it chipped that i could have it converted to SOHC to run on my boosted d16. i know its pretty much the same ecu or close to it minus the fact its made to run a DOHC and has a higher redline.. can it be converted?? i searched but no luck...
Old Oct 29, 2009 | 07:09 PM
93turbo16's Avatar
Default Re: p30 on a SOHC??
It isn't being "converted" you are just putting a D16 basemap on the chip. All obd1 civic/integra ecus share the same code. So you can interchange the program on any ecu to run any of the other engine models without a real problem.
You just have to disable the proper sensors for the ecu/car and it will work just fine.
Old Oct 29, 2009 | 07:13 PM
j.packsb's Avatar
okk thanks i understand now. so would i be lookin at an extra charge to get the ecu adjusted to run my setup vs. how much i would pay to get a p28 chipped for me?
Old Oct 29, 2009 | 07:19 PM
93turbo16's Avatar
You could use either one.
If the P30 is already chipped, then just get the reprogrammed.
Old Oct 29, 2009 | 07:20 PM
j.packsb's Avatar
no its not chipped yet but i got it for 40 bucks which i figured is cheaper then the 85-100 ppl want for a virgin p28
Old Oct 30, 2009 | 03:20 AM
GhostAccord's Avatar
The real cost that comes with buying a chipped ECU is having it tuned on a dyno. Just becuase your freind has a car with a similar setup does not mean that his ECU will run well in your car. A base map bought from a company, or downlaoded from someone that does not have access to your car. Will not run as well as a properly tuned one will. Most companies that supply base maps with chipped ECUs will have a disclaimer. Stating that the ECU should be tuned for optimum performance as soon as posible. Then it is up to you, the owner, to have it done.
Old Oct 30, 2009 | 09:23 AM
j.packsb's Avatar
^^^ im aware of all that. im not gonna put the ecu in until the same day i get tuned. im jus saying it has to be chipped first in order to be tuned. im askin is will it cost more to chip it for my car since its orginally a dual cam ecu..
Old Oct 30, 2009 | 09:47 AM
No
Dual cam or single cam has no bearing on the actual chipping of the ECU.
tacosandbeans
Apr 8, 2010 03:02 PM
j.packsb
Oct 29, 2009 07:16 PM
kaoticivic
Jul 16, 2002 05:55 PM
