No VSS need to retune help!
Old Oct 19, 2009 | 11:49 AM
jayman322's Avatar
Default No VSS need to retune help!
Ok, here's the situation, theres something mechanical keeping me from VSS, it never worked after I got the quaife installed to the tranny at honda and acura specialists in ATL. When i had cromepro the vss was diabled and the tune was pretty good. well my chip took a dump on me and I'm in a new state and going to a new tuner very soon with no vss. I was thinking I could change platforms while i have this opportunity but i'm no realizing that with no vss i might be screwed. What tuning platforms will operate without vss? can i get hondata? any help would be greatly appreciated. thanks, Jason
Old Oct 19, 2009 | 12:01 PM
HRTuning's Avatar
Default Re: No VSS need to retune help!
They all have a setting to disable VSS and operate VTEC without VSS, if that's what you're referring to.
Old Oct 19, 2009 | 12:45 PM
TurboLSVtecTeg's Avatar
Why dont you just tear the transmission apart and install the speedo gear onto the differential. It was probably forgot about and not installed on the new differential. You could run it without the speedo hooked up. But then you wont have gear based corrections and wouldnt beable to run gear based boost control.
Old Oct 19, 2009 | 01:37 PM
jayman322's Avatar
sorry i was in no hurry to tear up the tranny, cuz i'm not some kind of honda genius but maybe now is the time while the car is down anyways to investigate this thing further. what am i missing without running vss, will my tune be any different? it would be helpful to know how fast i'm going too lol.
Old Oct 20, 2009 | 06:00 AM
You dont need to have the VSS too properly tune a car no. But it is nice on certain situations and when checking over logs.
soninihon
Nov 8, 2015 09:42 AM
speedfreak44
Dec 29, 2013 09:46 PM
jdmmugeneg6
Transmission & Drivetrain
Oct 3, 2011 04:08 PM
GraphiteMW
Mar 7, 2010 07:05 AM
rawkus
Sep 5, 2006 06:24 PM
