New to EGT, is this safe?
Old Oct 4, 2009 | 03:11 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default New to EGT, is this safe?
Car in sig is fully tuned, just installed an autometer EGT into the 3rd runner of the turbo manifold, about 1.5" from the head. The readings are as follows in F.
Idling = 950-1050
15 ingh cruise = 1250 - 1350
10 inhg cruise = 1400 - 1520
1-2-3-4 WOT = 1600 by the end of the run.
I have done as much research as I could, and find that these numbers are pretty high in comparison, but find usually that people are mounting their probe either in their collector, or just after the turbo, which has to be at least 100 deg difference right?
Any input is greatly appreciated!
Old Oct 4, 2009 | 05:02 PM
non-VTEC's Avatar
Default Re: New to EGT, is this safe?
i noticed mine was pegging 1600deg plenty of times in the past. no matter what i did to the fuel/timing maps the temps were the same. depending on how well your exhaust flows the temps may change a little if it's completely straight flowing but on turbo honda's the temps tend to run that hot normally. i don't use egt anymore for that reason...it seems to be a useless tuning tool. just don't hold it at 1600 for long periods of time and you will be fine.
Old Oct 14, 2009 | 09:57 PM
gstrudler's Avatar
Doesn't seem like the gauge is doing you much good if it's just pegging when you need it most. I would suggest at least moving it down the runner so you can tell if one day it is running hotter than usual.
Old Oct 22, 2009 | 02:31 PM
jonbar87's Avatar
usually anything >1800 is starting to get dangerous
Pullig
Jul 21, 2014 10:15 PM
oneludesol
Oct 5, 2009 12:51 PM
Blindstuff
Jun 2, 2004 09:51 AM
Canuk_SiR
May 18, 2003 08:38 PM
AlphaKennyWun
Oct 13, 2002 04:42 PM
