Can't data log when vtec is engaged! EcuControl
Old Sep 27, 2009 | 03:13 PM
shawn69's Avatar
Default Can't data log when vtec is engaged! EcuControl
As the title says, ecucontrol works great until i hit vtec, at any rpm. I get
Run-time error '8021'
Internal error retrieving device control block for the port.
Ecu Control crashes until i unplug the usb.
PS9, 1 wire vtec
turboedit ...
Disabled vtec and i can record all the way to redline.
Any ideas? I searched and found some people with the same problem but found no solutions.
Thanks
Old Sep 27, 2009 | 04:24 PM
HRTuning's Avatar
Default Re: Can't data log when vtec is engaged! EcuControl
VTEC is causing interference on the signal lines... which causes the USB device to lose communication... which causes your problem.
If you have a hulog or similar, take it out of the ECU if it's mounted or sitting inside... You can also try a different USB cable... A USB cable with a ferrite bead for noise reduction... Or fixing your grounds in your vehicle.
Old Sep 27, 2009 | 05:10 PM
shawn69's Avatar
Thanks for the reply. I'll try some of those suggestions.
I'll update if i get it to work or not.
Old Sep 28, 2009 | 06:01 PM
shawn69's Avatar
I think i fixed it.
What happened was the wire to vtec was really close to a spark plug wire, moved it as far away as i could...
Now i can datalog all the way to redline it seems if i let the engine decelerate with the car in gear still. If i just clutch in it still gets the error. Weird.
Vegas H22Prelude Si
Oct 15, 2007 07:12 PM
jedsus
Jun 14, 2006 06:52 PM
vtecn8ive
Apr 20, 2006 09:14 PM
05 S2K Stoner
Oct 28, 2004 06:40 AM
5 Liter Eater
Jul 16, 2001 09:57 AM
