Code 10 and 14
Old Nov 19, 2009 | 09:24 PM
MRsol's Avatar
Default Code 10 and 14
I have a 89 hatch with a D16Y7 swap. The check engine light is on. I went to aamco and the codes that came out are 10 and 14. I went and bought a new Intake temp sensor and when i went to install it, i realized that the intake is not a stock intake, so there isn't the stock location to install it. The 10 is the ICV (idle control valve)/ circuit. Has anybody had this problem?? Can i jumper it somehow?
Old Nov 22, 2009 | 06:52 PM
xenocron's Avatar
Default Re: Code 10 and 14
10 is IAT and 14 is IACV
you probably have the plugs reversed and plugged in to the wrong item
Old Nov 29, 2009 | 05:19 PM
andrewd_89's Avatar
as far as your IAT problem if you want to fix it you can buy an AEM inlet air temp sensor from ebay motors for around 50 bucks you will just drill a hole in your intake pipe, and weld or jb weld the bung on and splice the wires into your stock harness. Your IACV problem is going to have to involve you getting a multimeter and downloading a helms manual and following the troubleshooting tree for that code.
gr33ncivic
Apr 15, 2008 09:38 PM
IHEARTMYHONDA91
13
Feb 20, 2008 09:20 PM
Intellect
Feb 3, 2006 12:10 PM
delsol2005
Aug 4, 2005 07:20 PM
Vteg02
Jul 19, 2001 09:05 PM
