Adding Analog sensor to S300
Old Nov 24, 2009 | 09:49 AM
SPOOLINmatt's Avatar
Default Adding Analog sensor to S300
I want to wire in a fuel pressure sensor to s300 and i know there is 2 analog inputs and how to use those BUT...where the hell do i get the 5v supply for the sensor? Regulator?
Old Nov 24, 2009 | 11:30 AM
GhostAccord's Avatar
Default Re: Adding Analog sensor to S300
Are you looking for where to buy an analog pressure sensor?
http://www.innovatemotorsports.com/x...cat=265&page=1
12v input 1-5volt linear output
Or are you looking for a 5volt power source (wire) to give power to the sensor?
What car/chassis are you putting this in?
You could tap into the VCC2 (5v sensor power source)
OBD1 = ECU pin D20 (YEL/WHT)
OBD2 = ECU pin D10 (YEL/BLU)
Old Nov 24, 2009 | 05:38 PM
oh well if that one is only 10$ more than the one i was looking at then that is more convenient. PCS has a slew of sensors and transducers that are 5v input...
bopbop93030
Audio / Security / Video
Aug 14, 2009 06:15 AM
530guy
Jan 2, 2007 07:44 AM
CapnChunk
May 1, 2003 06:47 AM
sieger
Sep 6, 2002 10:33 AM
