Newbie when it comes to chip ecu?
Old Dec 9, 2009 | 04:57 AM
PHAT-INTEGRA's Avatar
Icon2 Newbie when it comes to chip ecu?
I just got my JDM P30 ECU chip thru Xencron. They have sent me an extra chip. I was looking at my ECU. I notice there is no socket for a laptop plug in. Is there already a base map installand how can I adjust any setting or do I have to get another chip burn and reinstall? I also have an AEM Wideband waiting to get install so I'm lost with this whole chip ECU thing.
Old Dec 9, 2009 | 07:12 AM
HRTuning's Avatar
Default Re: Newbie when it comes to chip ecu?
If you ordered a basemap you have a basemap on it. You need a chip burner to be able to make changes. With that chip burner you can read the chip in as well and see what's on it.
Old Dec 9, 2009 | 07:29 AM
Thanks, If I want to add in on board computer. I need to get that demond data loger install on the cuircut board to hook up the laptop?
Old Dec 9, 2009 | 08:32 AM
Relic1's Avatar
if you wish to datalog you need a laptop, a datalogging cable and the connector for the datalogging cable soldered into the board. (if it's not all ready there)
You will need to contact Xenocron to find out which program he used to create your basemap and if datalogging is enabled.
I think you were refering to the Moates Demon, it is a device that combines datalogging, emulation and a few other features into one device, not required to datalog.
Old Dec 9, 2009 | 09:06 AM
HRTuning's Avatar
The Demon will allow you to tune in real-time, datalog in real-time with a laptop, and if you get the NepTune RTP software bundle it will also allow On-Board datalogging where you can set it up to automatically save datalogs on the device so you can download them later with a computer. I think that's what you were referring to.
If you just want to be able to datalog with a PC, all you need is what he mentioned above.
Old Dec 10, 2009 | 05:09 AM
Thanks, Now I understand about the hardware. Software part I can learn it thru freinds. I requested eCtune when I sent Xencron my ECU.
Old Dec 10, 2009 | 07:03 AM
HRTuning's Avatar
Just getting an eCtune chip doesn't entitle you to the software or tuning package. eCtune's Pro package requires an Ostrich and doesn't allow you to burn chips. You won't be able to modify the bin you have if that's the case.
WeB
Engine Management and Tuning
Jan 19, 2010 11:17 AM
revlimitcrx
Apr 13, 2006 02:17 PM
cr-x si
Aug 10, 2003 09:22 PM
