obd0 PR4 conversion
Old Nov 10, 2009 | 09:38 AM
Clipsed's Avatar
Default obd0 PR4 conversion
ok, so I have searched and searched with no luck. Even pgmfi.org doesn't have my answer. What I need to know is what has to be modded on an OBD-0 PR4, NOT OBD-1, to convert it to a manual ecu. Thanks in advance.
Old Nov 10, 2009 | 02:34 PM
Clipsed's Avatar
Default Re: obd0 PR4 conversion
bump, no one has an answer?
Old Nov 12, 2009 | 12:06 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
i think all you have to do is chip it... i cant remember off hand, but i think there are only a few small hardware differences between ecus...and as long as you use the manual trans code it should work fine. and dont the auto integras have a separate module for the transmission?
i'll have to pull up my schematics...sorry i dont have a definitive answer for you.
i was going to try this before, but ended up using a pm6.
Old Nov 12, 2009 | 01:05 PM
Clipsed's Avatar
well I mean it was only a temporary fix, but today I will be picking up some ecus so I guess it really doesn't matter now. Be nice to know the answer though.
nousername
Mar 31, 2021 12:49 PM
neofreak
May 20, 2007 06:17 PM
neofreak
May 20, 2007 06:16 PM
ivanson
Oct 19, 2006 10:56 PM
Danethomp
Apr 23, 2004 06:32 PM
