Code 20 (ELD) 89 crx OBD 1 conversion
Old Nov 19, 2009 | 05:54 AM
PR8urVtec's Avatar
Default Code 20 (ELD) 89 crx OBD 1 conversion
Ok, I just installed my OBD 1 LS motor in my crx. It has Hondata S300 installed in the ECU. I am getting two codes. One is a water temp sensor which i will replace. My concern is the ELD (code 20). Can I disable this with hondata or do I need this b/c im obd 1? If I need to use it where should I start. I have seen people replacing the underhood fuse box and others replace the alternator. Any help would be great.
Thanks,
Ryan
Old Nov 19, 2009 | 07:18 AM
93turbo16's Avatar
Default Re: Code 20 (ELD) 89 crx OBD 1 conversion
Just disable this code in Smanager. You won't have any issues running the car without it.
Old Nov 19, 2009 | 08:09 AM
PR8urVtec's Avatar
Thats what I did but I just wanted to make sure that I didn't need that enabled for my car. I know the JDM cars do not use it. What happens when you shut it off? Why do they have it if I don't use it? I'm just curious about why US cars got equipped with this function.
Old Nov 19, 2009 | 10:21 AM
93turbo16's Avatar
Basically the ELD (electrical load detector) just senses when there is more draw on the system... say when you turn the defrost on or headlights. It has an additional fuel correction table that it adds/subtracts a small amount of fuel, also ignition/idle, etc.
There are 0 draw backs of disabling this sensor in most cars. It really isn't that big of a deal. Most softwares use the ELD input as the wideband logging input since it is a factory 0-5v input, which is exactly what most wideband output wires are.
Old Nov 19, 2009 | 10:59 AM
PR8urVtec's Avatar
Nice, I was going to use that wire with the PLX M300. Thanks a lot man. I appreciate it.
Ryan
Old Nov 19, 2009 | 11:23 AM
93turbo16's Avatar
Ryan
That should work great then. When logging through the ELD input on the ecu it is also recommended that you remove two resistors in the ecu.
They are located at R136 and R138.
Old Nov 19, 2009 | 11:57 AM
PR8urVtec's Avatar
Can I just clip them out on the ends? Or do I need to desolder them?
Old Nov 19, 2009 | 12:01 PM
93turbo16's Avatar
You can just clip one end of them and pull it up. You don't have to desolder them unless you want to.
Old Nov 19, 2009 | 12:10 PM
PR8urVtec's Avatar
Nice. I will do that when the time comes. Thanks for the help.
Old Nov 24, 2009 | 12:26 PM
LudeLooker's Avatar
Is there any reason why this should be removed if your datalogging over ELD with a w/b O2? I am just curious as I will be datalogging soon (I am playing with it now but my wideband needs to be hooked up and my sensor replaced). I didn't see this in the s300 docs, or is this for other tuning systems primarily?
Old Nov 24, 2009 | 01:46 PM
93turbo16's Avatar
This is for pretty much any software that you use that logs through the ELD input.
The resistors skew the voltage coming in from the ELD pin. So when you remove these it will be pretty much spot on when logging in the software. This is so you don't have to use the wideband offset parameter in logging.
uhhmaysing
Jul 18, 2014 11:07 AM
kevcha711
Jan 20, 2010 02:42 PM
88hfef8
Apr 21, 2008 05:03 PM
DA9muthaFocka
Feb 4, 2006 03:34 PM
Turboracer01
Feb 10, 2004 05:55 PM
