Alpha-N mapping with CROME
Old Nov 7, 2009 | 12:48 PM
cyanid3's Avatar
Default Alpha-N mapping with CROME
Hi. I want to do a TPS vs RPM map in CROME. However, even with the ITB tools plugin, half of the columns in the table are still for MAP values. Is there any way I can make a full TPS vs RPM map with CROME? Thanks in advance!
Old Nov 8, 2009 | 12:06 AM
cyanid3's Avatar
Default Re: Alpha-N mapping with CROME
Bump. Help, please?
Old Nov 8, 2009 | 08:54 AM
HRTuning's Avatar
No, you can't. The Alpha-N in crome wasn't designed that way. Get something better.
Old Nov 8, 2009 | 08:57 AM
cyanid3's Avatar
So the tune HAS to be MAP - TPS, with crossover only?
Old Nov 8, 2009 | 09:29 AM
HRTuning's Avatar
For crome, yes. It wasn't designed for anything else.
Old Nov 8, 2009 | 09:32 AM
cyanid3's Avatar
Thanks, will look for another solution for my next build.
Old Nov 8, 2009 | 09:52 AM
HRTuning's Avatar
No prob. Check out NepTune.
Old Nov 8, 2009 | 10:18 AM
GhostAccord's Avatar
eCtune has pretty good Alpha-N tuning capabilities as well.
Old Nov 9, 2009 | 09:57 AM
Relic1's Avatar
Crome is quickly slipping out of it's usefulness.
both Neptune and eCtune have good TPS based mapping.
Old Nov 9, 2009 | 10:10 AM
cyanid3's Avatar
Does Neptune work with just a chipped ECU or does it need a Demon? I have an Ostrich 2.
Old Nov 9, 2009 | 10:12 AM
RC000E's Avatar
This is all true, but you can alter the TPS/Map crossover threshold to make it quite workable.
(Above) Neptune uses an installed daughter board like S300. The ecu needs chipped with a socket and necessary chipping parts and a datalogging port needs installed. There are then some small modifications made to the case and by bending over some components near the J12 location. There is also the Neptune dealer option which allows your car to be tuned, a chip burned then simply just popped into a chipped ecu. One option allows continual changes to be made on the fly, one requires you go to a tuner.
carlos8
36
May 4, 2014 05:42 AM
boostedcivicsir
Jul 24, 2007 06:17 AM
jacky599r
Jan 9, 2006 07:25 PM
B16A1-EF9
14
Aug 27, 2005 09:30 AM
