tensioner problems fml
Old Oct 12, 2009 | 12:49 PM
Cire's Avatar
Default tensioner problems fml
So ive been working on my new build for my single cam and decided to do a new timing belt water pump and tensioner. But when we put everything on and timed it we discovered the hole threads were stripped, we tried doing a mild retap but didn't work out quit well. I'm in a bit of a predicament and could use some advice, anything but a new block or involving a shop.
Old Oct 12, 2009 | 12:50 PM
Simkin314's Avatar
Default Re: tensioner problems fml
Which holes are stripped?
Sorry, You could drill/retap to larger bore
Old Oct 12, 2009 | 12:52 PM
Cire's Avatar
the hole for the tensioner bolt, the actual threads in the block are stripped
Old Oct 12, 2009 | 12:53 PM
HRTuning's Avatar
If you post this in the correct forum, Tech/Misc, the right people might see it and you'll likely get a response.
Old Oct 12, 2009 | 12:58 PM
Simkin314's Avatar
Well you might be able to drill the hole out one size and re-tap using a different size bolt...If that's not an option, I can't think of anything else. Sorry, I'll give it some thought.
Old Oct 12, 2009 | 12:59 PM
Cire's Avatar
found this
http://www.diylife.com/2008/04/23/st...thread-repair/
Old Oct 12, 2009 | 01:04 PM
Simkin314's Avatar
That's pretty nifty, update if it works well.
reagan_illest
Welding / Fabrication
Mar 8, 2014 01:06 AM
chope045
11
Aug 15, 2011 11:16 PM
methos713
May 5, 2008 12:29 AM
trevor72
Jun 7, 2006 09:55 AM
sleepin91teg
Jul 12, 2004 02:42 AM
