itbs with s300
Old Oct 9, 2009 | 08:02 PM
JDM JEFFREY's Avatar
Default itbs with s300
how are u guys tuning ITBS?
map or tps?
Old Oct 9, 2009 | 10:19 PM
mtber's Avatar
Default Re: itbs with s300
alpha-n which uses tps as primary and map as secondary references.
Old Oct 12, 2009 | 01:22 PM
MONSTERek4's Avatar
USE TPS TO TUNE ITBS TRUST ME LOL UNLESS YOU HAVE A REALLY GOOD VACUUM BOX
Old Oct 12, 2009 | 01:29 PM
DDTECH's Avatar
tps is easiest.
Old Oct 12, 2009 | 04:46 PM
scmil95eg's Avatar
I used MAP + TPS with crome, but I didn't like crome for a multitude of other reasons.
easily 95% of our V8 units use MAP.
Maybe 15% of our Honda units use MAP.
For the few who know who I am, in all sincerity, this is not a sales pitch - but I truly believe that if synchronization could have been guaranteed for this scene 10 years ago, the general opinion on this topic would be different. When each runner has a different vacuum signal because tolerances aren't tight or consistent, you'll chase your tail indefinitely.
I feel I should add; even if you do run MAP for load, on most stand alone management systems you can still choose TPS based accel fuel - which is nice to supply a big 'hit' with minimal threshold. Not sure on S300 though....
Old Oct 12, 2009 | 05:00 PM
GhostAccord's Avatar
to synchronizing.
I bought a Sync Pro Carb tuner as soon as I finished building my manifold. I have only used it on a few bikes so far and it works great.
Old Oct 12, 2009 | 05:13 PM
scmil95eg's Avatar
Originally Posted by GhostAccord
to synchronizing.
to you for synchronizing. so many don't.
it makes such a huge difference for idle and initial tip-in.
Old Oct 12, 2009 | 05:44 PM
we synchronized them before we tuned ...some people say tune with tps and some say with map.??
and with s300 the tps sinal keeps changing? after the car is turned off???
Old Oct 12, 2009 | 05:52 PM
What TPS sensor are you running, stock Honda? Is there any way to calibrate your TPS in SManage?
DDTECH's Avatar
your voltage changing when your car is off?
you should be able to use a custom volt tps setup in hondata.
Old Oct 12, 2009 | 05:55 PM
scmil95eg's Avatar
If you put a multimeter on the signal output from the TPS, does it follow what the ECU is seeing?
If it's a good TPS, I'd say it's:
1. voltage to TPS issue
2. ground plane for TPS issue
3. ecu issue
That shouldn't wander if you're not moving it.
Old Oct 13, 2009 | 11:55 AM
YFZpilot's Avatar
the best way is actually tuning by both, there is an option to use the map at high vacuum zones then switch over to the tps.
likwidchz
Engine Management and Tuning
Aug 9, 2016 05:12 PM
Bbasso
Jan 25, 2005 06:09 PM
rattletrap
May 24, 2003 04:27 PM
