Need a ls/vtec base map
Old Nov 22, 2009 | 08:13 PM
550whpcivic's Avatar
Default Need a ls/vtec base map turbo
Just almotor right now but here's the specs
B18b1 block
crower rods
84mm cp 9-1 pistons
b16 head 1mm over 3 angle valves
Victor x intake
gsr injectors
gsr cams
stock throttle body
daton sleeves
adj fuel pressure
Looking for a good base map with some dyno numbers if you have any
Old Dec 2, 2009 | 04:20 PM
abusedvtec's Avatar
Default Re: Need a ls/vtec base map
what r u tuning with id go with gsr usdm map i swaped a ls vtec into m 94 gsr and ran with stock gsr map on hondata for 7-8 months brought it to dyno made 143 hp and 109ftlbs i low comp no boost also like yours
Old Dec 5, 2009 | 11:06 PM
speedbynumbers's Avatar
B18b1 block
crower rods
84mm cp 9-1 pistons
Victor x intake
gsr injectors or will get dsm 450s if needed
gsr cams
stock throttle body
daton sleeves
adj fuel pressure
If your running Hondata S300 go to Hondat's website and search under forums and click on calibrations there you should find a base map to use. Sure stock gsr map will work but remember the bigger the motor the more air you move the more fuel required. If you don't have the Hondata hit me up I'm a dealer and just remind me of this thread and I'll give you a deal.
Old Feb 12, 2010 | 09:54 PM
So you think a stock gsr map will work fine for awhile? yes using hondatas300
Old Feb 13, 2010 | 04:19 AM
Natural Aspirations's Avatar
Its going to run like poop on a stock map, btw. Not much chance of anyone having a great tune for a boost motor minus boost
Old Feb 13, 2010 | 03:50 PM
Well right now im running a gsr map and it moves pretty good..
But right now i have on there
T3 top mount with 44mm wg
60-1 turbo
1000cc injectors
3bar map gm
3inch exhaust
Old Feb 14, 2010 | 11:34 AM
civickiller's Avatar
i got a uberdata lsvtec map dynoed 161whp flatened dc header.
same lsvtec motor with rmf replica header, stock gsr map ran it, a/f were close to where it should be
Old Feb 26, 2010 | 06:01 PM
Ok now i need one with a 60-1 turbo
K20.ek
Engine Management and Tuning
12
May 3, 2018 06:20 PM
jhendry
16
Oct 19, 2013 10:42 AM
DSRxMilogen
Jun 27, 2005 12:49 AM
migs
Nov 19, 2003 03:36 PM
