moates burn2 problems ! CROME 1.5.3
i go to settings, have it on com port 4 , baud rate 920000, and i test connection. "successfully connected to ecu"
but when i go to burn the bin. it says no connection detected. :/
then, i close crome, i re-open it, and reopen my bin file.
i hit write , and it says "the operation failed after 3 attempt(s) with 250 milliseconds between each attempt.
I'm not Rick!
Re: moates burn2 problems ! CROME 1.5.3
are all the wires in the ribbon dealy in good shape?
sometimes putn the cover on the ecu can cut that ribbon.
did you try another laptop? it could be the driver
i had lots of problems with the driver not working. and i had to upload new ones via internet..
im getting hondata s300 soon. i know its more $ of course
with crome i cant get a redline to work.
vtec isnt consistent.
iacv activity flucuates and isnt consistent
and several laptops have to fight to connect to the ecu
lots of people like crome but i think it still has so many problems its not worth even downloading for free.
and yes, this is the 3rd laptop ive tried. still nothing.
It's 921600, not 920000. You'll have to manually enter it, since the option apparently isn't available in the baud rate list. There's your first step to try.
still the same thing. i hit detect connection, manually entered 921600, hit apply, then closed crome, opened it back up, and still the same message.
The software sets the baud rate. It ignores the value that's shown in device manager.
The COM port and latency settings should be checked in device manager, though.
found out what it was. it was the 27fs512 compatibility option. i clicked on that, and now it burns freely. thanks for all the help fella's
a1320honda
Engine Management and Tuning
09-17-2014 05:42 AM
