cold air intake VS ITB
Old Nov 11, 2009 | 11:55 AM
Tong.Y's Avatar
Default cold air intake VS ITB
which is best for all motor
i'm looking for best in sound and performance
Tong.Y's Avatar
Default Re: cold air intake VS ITB
Old Nov 11, 2009 | 02:36 PM
GhostAccord's Avatar
They are two totally different things. You cannot compare one to the other. I think you should do a bit more research into what it is that you are asking.
Individual throttle bodies... aka ITBs are, in the case of a 4 cylinder, 4 separate throttles that are connected to the cylinder head to feed each cylinder individually. They are a type of intake manifold.
This is a pic of the individual throttle body manifold that I made out of a set of sport bike throttle bodies.
Where as a cold air intake is a tube that feeds cool air to an intake manifold. Sometimes from outside the engine bay. In this image the CAI is the 3" aluminum tube that is connected to the throttle body / intake manifold.
Note: You can also use an air box and CAI on ITB's as well.
In my opinion, a purpose built N/A motor with ITBs. Would perform and sound better than a cold air intake
Old Nov 11, 2009 | 02:44 PM
Sales@Bisimoto.com's Avatar
ITB's are going to create more power and can be driven daily but only if you have a tuner familiar with ITB set-ups. I would recommend a cold air intake for any mild/stockish street car
Old Nov 12, 2009 | 04:01 AM
unusual71's Avatar
ITBs require you run a fairly aggressive cam otherwise the cam instantly becomes the restriction in the engine and you won't notice a large gain. ITBs do great with the proper setup though and can even help get a smoother idle when running a large cam.
Old Nov 12, 2009 | 07:02 AM
92TypeR's Avatar
FSAE
Get both.
Make a plenum/air duct for the ITB's.
Old Nov 13, 2009 | 11:58 AM
Tong.Y's Avatar
damn seriously, i need to get high and bigger cams inorder to run an ITB properly?
Old Nov 13, 2009 | 12:01 PM
Tong.Y's Avatar
is there anything else that should be includes into the ITB setup and make it run proplerly?
Old Nov 18, 2009 | 02:39 PM
teamjdm239's Avatar
just cams,valve springs, titanium retainers,itb's,high comp,and a nice exhaust setup. that should do you justice.
Old Nov 18, 2009 | 03:33 PM
TunerN00b's Avatar
I think that part may have already been done prior to the original post...
casserlyshane
Oct 6, 2014 04:11 PM
logg_frogg
20
Sep 17, 2008 12:01 PM
alfaaay
Jul 13, 2005 01:07 AM
whatVTEC
Sep 19, 2003 10:42 PM
HX_Guy
Oct 17, 2001 09:46 AM
