k-pro & emissions
I am not too up on the requirments in Virginia. But as long as you only have to pass an OBD2 scantool test you should be fine as long as your OBD2 connector on your car is wired up to the KPRO properly and you don't have the OBD2 disabled in the KPRO. You can disable whatever codes you want and still pass the scan tool test you just cannot have the OBD2 completely disabled.
BTW you should be able to pass a tailpipe emissions test too as long as you have closed loop enabled in the KPRO and you have a catalytic converter on the car.
If there is a visual test in Virginia then you are SOL my friend.
Thanks for the info. Here in va we do the scan test so i just wanted to know if it would pass that way I had a obd1 ecu and i didn't pass now I want to do a k24/20 swap and just wanted to make sure it will work for my daily driver.
MeanGreenEG9
Dec 4, 2002 11:16 PM
