What Ignition System upgrades are compatiable with Crome?
Old Sep 10, 2008 | 05:39 PM
RHD EG H2B's Avatar
Default What Ignition System upgrades are compatiable with Crome?
Right now I have an upgraded coil but I want more.
What can be used?
Old Sep 10, 2008 | 06:07 PM
Tomdata's Avatar
Default Re: What Ignition System upgrades are compatiable with Crome? (RHD EG H2B)
anything that would work with a stock honda ecu will work with crome.
Old Sep 10, 2008 | 06:35 PM
mtber's Avatar
The factory honda ignition system is good up to around 600 whp.
Don't touch it if you don't need to.
Old Sep 11, 2008 | 03:10 AM
RHD EG H2B's Avatar
Default Re: What Ignition System upgrades are compatiable with Crome? (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">The factory honda ignition system is good up to around 600 whp.
Don't touch it if you don't need to.</TD></TR></TABLE>
Thats true.
So is there anything I can do to help it from killing distributors??
Old Sep 11, 2008 | 05:26 AM
GhostAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RHD EG H2B &raquo;</TD></TR><TR><TD CLASS="quote">
Thats true.
So is there anything I can do to help it from killing distributors??</TD></TR></TABLE>
Get rid of the upgraded coil. Check all your dist. wiring for shorts or bad connections and test your igniter unit.
Old Sep 12, 2008 | 04:29 PM
baller status's Avatar
Honda distributors really suck. If you're dead set on Crome, you're stuck with them. Unless you want to try the MSD distributor (I THINK it was MSD). I got sick of Honda distributors so I did what Bisimoto did.
Old Sep 12, 2008 | 06:47 PM
98vtec's Avatar
moderator emeritus
Default Re: What Ignition System upgrades are compatiable with Crome? (baller status)
what did bisi do?
coils?
Old Sep 13, 2008 | 03:48 AM
Default Re: What Ignition System upgrades are compatiable with Crome? (98vtec)
AEM Engine Position Module (EPM) & a CDI pencil coil setup. This type of setup is for someone with $2k to spend on an ignition.
AEM EMS
AEM EPM
AEM CDI Pencil Coils
= $1600-2k+ for all new parts
Yes you ebay used parts gurus may find this stuff cheaper used..... :headshake:
With this setup there is no doubt that you will have a very reliable engine management & distributorless ignition system.
<FONT SIZE="5">But!</FONT>
Being realistic here! This set up is not exactly required for a DD street car. Honda's ignition system works just fine for those of us keeping it under 10K RPM and 400WHP.
Old Sep 13, 2008 | 10:37 AM
RHD EG H2B's Avatar
Default Re: What Ignition System upgrades are compatiable with Crome? (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">AEM Engine Position Module (EPM) & a CDI pencil coil setup. This type of setup is for someone with $2k to spend on an ignition.
AEM EMS
AEM EPM
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">The factory honda ignition system is good up to around 600 whp.
One says they are good up to 400hp the OP say 600hp, I guess it just depends on your setup as a whole. Well I can vouch for the 600hp because I really made this much on a oem dizzy. I was wondering if theres any quick cheap upgrade that works with crome, as I dont have enough time to get a whole new EMS and ignition system, and get it all dialed in in time. I think Ill be going with the AEM setup described below. But thats now til I get a couple more thousands
Is there anything cheaper thats known to perform just as well, with the same reliability?
Old Sep 13, 2008 | 05:40 PM
JSPECSIR's Avatar
you can put an msd box on it or mallory, accel. there are lots of ignition amplifiers. alot of people on here have problems with msd stuff, but i think alot of it is more install related than product related, and the msd is more popular so thats what you hear the most about.
Old Sep 19, 2008 | 06:44 AM
00GsR-TeG's Avatar
get a msd replacement dizzy and rotor, with a aftermarket coil and an ignition amplifer and you should be good.
Making 600whp you might need to consider adding another fuel pump soon
Frost7177
Apr 17, 2008 12:56 PM
blackrag
11
Mar 4, 2007 11:03 PM
fasterthenU
Jan 23, 2006 08:05 PM
Dragline
Aug 22, 2004 07:36 PM
seppuku
Sep 16, 2003 10:30 AM
