ecu problemmmm need help please
Old Oct 7, 2008 | 10:15 AM
wowy978's Avatar
Default ecu problemmmm need help please
i got an obd1 ls motor,b18b,in my obd2 integra chassy.......and i was wondering if i used a obd2 ecu,will it throw a chek engine and if itll pass inspection
Old Oct 7, 2008 | 10:21 AM
mtber's Avatar
Default Re: ecu problemmmm need help please (wowy978)
It shouldn't throw a code unless you are missing a sensor which the obd2 ecu is looking for.
Old Oct 7, 2008 | 10:37 AM
HRTuning's Avatar
Default Re: ecu problemmmm need help please (mtber)
If all you did was swap the OBD1 engine in, then yes it will throw codes.
Old Oct 7, 2008 | 10:40 AM
wowy978's Avatar
i heard that it mite throw a chek engine bcuz of the crank senor...sum ppl say obd2 has a CS and an obd1 ls doesnt but im not sure
Old Oct 7, 2008 | 11:05 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wowy978 &raquo;</TD></TR><TR><TD CLASS="quote">i heard that it mite throw a chek engine bcuz of the crank senor...sum ppl say obd2 has a CS and an obd1 ls doesnt but im not sure</TD></TR></TABLE>
correct.
all though even that is one jumper away from being solved.
jrepko18
Engine Management and Tuning
20
Sep 26, 2014 06:45 PM
Mr.DC2TurBo
Oct 17, 2003 05:55 PM
gsr squirrel
Oct 8, 2002 06:45 PM
gsr squirrel
Oct 8, 2002 03:59 PM
