tps code only comes on in vtec? help
Old Oct 15, 2008 | 03:55 PM
tealsvteceg's Avatar
Default tps code only comes on in vtec? help
my cel light only comes on when i hit vtec and its code 7 for obd1 "tps" i just put a new throttle body on and i adjusted it right? idk whats wrong?
Old Oct 15, 2008 | 09:57 PM
Spody02's Avatar
Default Re: tps code only comes on in vtec? help (tealsvteceg)
whats you put your volts at for tps sensors?
Old Oct 17, 2008 | 03:43 PM
Default Re: tps code only comes on in vtec? help (Spody02)
i checked the voltage on the tps when i had it on the stock throttle body and it was 5.3 so thats what i set it to...
Old Oct 17, 2008 | 06:08 PM
zccr-xsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tealsvteceg &raquo;</TD></TR><TR><TD CLASS="quote">i checked the voltage on the tps when i had it on the stock throttle body and it was 5.3 so thats what i set it to...</TD></TR></TABLE>
the tps is prob. getting weak did u replace itwith a new one?stock honda voltage is
closed throttle 4.5
WOT 5 volts
what wires are u useing to test?prob the center wire of the tps plug.the one closet to the firewall is your ground.
Old Oct 18, 2008 | 10:43 AM
Default Re: tps code only comes on in vtec? help (zccr-xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">
closed throttle 4.5
WOT 5 volts
i didnt replace it cause it worked fine before i put it on the throttle body.
my voltage is set the same as it was when the tps was on the stock tb which was 5.3 at WOT
im testing the right wires cause when i move the throttle my voltage goes up and down...
Old Oct 20, 2008 | 05:23 PM
it seems like this tps problem happens alot and no ones figured it out...
Old Oct 21, 2008 | 03:27 PM
dcvt16's Avatar
closed throttle 4.5
WOT 5 volts
Stock honda voltage is 4.5v at WOT.
and in the range of .30- .50 at closed throttle
Old Oct 21, 2008 | 03:57 PM
zccr-xsi's Avatar
Default Re: tps code only comes on in vtec? help (dcvt16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcvt16 &raquo;</TD></TR><TR><TD CLASS="quote">
and in the range of .30- .50 at closed throttle</TD></TR></TABLE>
lol ooook thats why people have tps problems.i set mine to .45 closed 5 volts wot and my tps never acts up.
Modified by zccr-xsi at 8:36 PM 10/21/2008
Old Oct 21, 2008 | 04:12 PM
zccr-xsi's Avatar
i bet if u got one from blox or inline four your problem will go away.
Modified by zccr-xsi at 8:37 PM 10/21/2008
Old Oct 21, 2008 | 06:04 PM
Modified by zccr-xsi at 8:37 PM 10/21/2008</TD></TR></TABLE>
idk i never read about them myself... two of my friends use them and i hear there good.
Old Oct 21, 2008 | 06:07 PM
its a professional products throttle body
Old Oct 22, 2008 | 06:02 AM
zccr-xsi's Avatar
idk i never read about them myself... two of my friends use them and i hear there good.</TD></TR></TABLE>
and btw there not alot of money there fairly cheap.and like i said before tps get weak being so old.what i mean by weak is the signal wire isnt reading what it should.ive seen them springs on the side that goes in the t/b get so weak u can move it with your \hand and it wont spring back like it should.
Old Oct 22, 2008 | 04:08 PM
it works fine. it just throws a cel light around 7 grand...
Old Oct 23, 2008 | 04:26 PM
any other ideas?
Old Oct 23, 2008 | 09:00 PM
Turbo-charged's Avatar
5.3 volts is way over 100% throttle. thats probably where your problem is.
set it to 4.5v WOT and see what happens. ive had that exact same problem where it triggers the cel only at high rpm. the problem was the tps voltage being too high, just like yours is now. and before you say "it was fine before" doesnt mean that it was right.
4.5v closed and 5v open? come on now. neither one of those values are correct lol
Old Oct 25, 2008 | 05:18 AM
crashsvg's Avatar
Default Re: tps code only comes on in vtec? help (Turbo-charged)
was this problem sorted out
Old Oct 27, 2008 | 01:01 PM
Default Re: tps code only comes on in vtec? help (crashsvg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashsvg &raquo;</TD></TR><TR><TD CLASS="quote">was this problem sorted out
not yet, im gonna go mess with it and see if i can fix anything.
Old Nov 2, 2008 | 09:21 PM
i just figured soething out tonight. its not that my cel light turns on at high rpm its if i hold it floored for a couple seconds, then it comes on... at any rpm.
Old Nov 3, 2008 | 02:59 AM
RACEPAK's Avatar
then its the tps.
Old Nov 4, 2008 | 12:17 PM
Default Re: tps code only comes on in vtec? help (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">then its the tps.</TD></TR></TABLE>
haha... uh yea i alredy no that... but see im trying to figure out why its coding but i think i got it figured out. i just gotta work on my car....
Old Nov 11, 2008 | 01:05 AM
z3r0's Avatar
I'm having the same damn problem with my B18C SI (JDM spec cos i live in Asia).
I have no access to after market TP sensors cos i'd have to export them. Will try a few of the suggested tests. Last hope is to head to the halfcut shop and get a new TB hoping to get a good TPS.
Old Nov 11, 2008 | 06:50 PM
z3r0's Avatar
Default Re: tps code only comes on in vtec? help (z3r0)
Any word on the fix?
Old Nov 12, 2008 | 04:27 PM
well i tried to adjust my tps and it wont go lower than 15.01 at WOT and ive tryed 2 tps's!? the only way i could get it to read 4.5 at WOT is to mess with my throttle cable or try something else? i think the mechanism that moves the tps on my tb is adjustable too? ill check it out tho...
Old Nov 12, 2008 | 07:08 PM
z3r0's Avatar
I can only give it a shot on my side of world this weekend. Probably on Saturday if possible if not i'll have to wait til weekend after next.
Does your throttle cable seize up, as in its hard to depress the accelerator sometimes? Cos it happens to me sometimes. I thought that might be a problem that is related to the TPS sensor.
Wait... you said at WOT its at 15.01?!?!?! Isn't that like way too much?
Modified by z3r0 at 11:15 AM 11/13/2008
Old Nov 14, 2008 | 04:11 PM
the throttle cable is fine. and i meant to type 5.01 volts
