cel with crome- stumpd
Old Oct 8, 2008 | 10:48 AM
turbociv910's Avatar
Default cel with crome- stumpd
hi all, i chipped my new p72. Its in a 99 civic, it has a cel, and it will not rev over 3k. Any ideas? Using crome with a p72 basemap
Old Oct 8, 2008 | 11:39 AM
HRTuning's Avatar
Default Re: cel with crome- stumpd (turbociv910)
Congratulations, you're in limp mode.
Either the ECU wasn't working to begin with (Cut J1 to test), your chipping job is bad, or the chip isn't burnt properly/setup correctly.
Check over everything.
Old Oct 8, 2008 | 07:50 PM
Default Re: cel with crome- stumpd (HRTuning)
got it fixed.. thanks
Old Oct 8, 2008 | 08:08 PM
98vtec's Avatar
moderator emeritus
and that would be?
Old Oct 8, 2008 | 08:20 PM
Default Re: cel with crome- stumpd (98vtec)
removed check sum under plug in manager, the regular remove check sum didnt work under plugins<enhancements
RiipTiide67
Engine Management and Tuning
Jan 16, 2012 06:57 AM
hucoreyCRX
Jun 29, 2009 05:39 AM
SinsEvil666
Feb 28, 2008 09:25 PM
gtcaraudio
Jan 25, 2008 06:57 PM
h8tred
Jul 7, 2003 08:35 PM
