ob2b to motec harness
Old Sep 4, 2008 | 04:18 PM
turbociv910's Avatar
Default ob2b to motec harness
My civic will like this.
i am working on it now.
Old Sep 4, 2008 | 11:05 PM
mtber's Avatar
Default Re: ob2b to motec harness (turbociv910)
Cool idea :-)
You should look into the quality of the pins & soldering on the obd2 side of that harness. I have seen a lot of cheap china made obd2 to obd1 harnesses come apart.
Old Sep 5, 2008 | 03:59 AM
Default Re: ob2b to motec harness (mtber)
yeah i have noticed, i have been very carefull not to bend the wires very much
Old Sep 5, 2008 | 08:14 AM
mtber's Avatar
Wrap the obd2 side in epoxy clay. Next time around go ahead & use a quality obd2 to obd1 harness :-)
Old Sep 5, 2008 | 08:50 AM
where can i find one of those?
this particular one came from streetlightz.com
wiring is done other than com cable. next is to cut or clean up the unnecessary wires.
Old Sep 6, 2008 | 02:48 AM
mtber's Avatar
The harnesses we sell use the same pin design but with better solder, plug & wire quality.
For the application you are producing, just use some epoxy to hold everything in place on the obd2 side.
jazzRS
Sep 28, 2012 03:16 PM
appelsos
11
Jul 11, 2011 06:24 PM
shocker911
Mar 23, 2011 07:33 PM
eJ6DM
Oct 10, 2006 07:12 PM
civtegra_hybrid
Sep 14, 2004 01:29 AM
