question about AFC's
Old Sep 9, 2008 | 06:52 AM
Dave H's Avatar
Default question about AFC's
I have been tuning domestic stuff for years, have many championships and wins in various types of racing to my credit, but now I am playing around with some import stuff. I have Hondata down pat (S300 and Kpro), along with most other stand-alone management systems, but I have a question about the AFC's (such as the neo).
I understand that all you are really doing with these is skewing the map reading the computer see's to correct A/F ratio, but if you have to go negative on the AFC, doesn't the lower map signal coming from the AFC to the computer effect timing as well? If you have to take 20% out on the AFC to correct for larger injectors, doesn't the computer see a 20% loss of map, which would cause the computer to add a bunch of timing since the timing map of the computer at 20% loss of map is much higher?
If you look at hondata, and pull up the stock timing tables, there is a 6-8 degree difference between 100kpa and 80 kpa (a 20% loss). That would mean that you would be running as much as 8 degree's additional timing at WOT than you should.
Am I missing something, or have something confused?
Thanks
Dave
Old Sep 9, 2008 | 07:07 AM
Relic1's Avatar
that is the very reason why VAFCs kill engines.
There are way to many programs out there that edit the honda ECU's programming to even consider strapping a AFC of any sort into a honda.
As far as in other manufacturer's cars, a little change is all I'd do. Any resizing of injectors or serious changes and you're asking for short engine life.
Old Sep 9, 2008 | 09:34 AM
Dave H's Avatar
Default Re: (Relic1)
Thank you for confirming Relic, I just wanted to make sure I was thinking straight.
-Dave
Old Sep 9, 2008 | 11:19 AM
Relic1's Avatar
you're on the right track.
BTW - http://forum.pgmfi.org/index.php is a great tuning source if you haven't all ready found it. (searching on there is really important and valuable)
Old Sep 11, 2008 | 10:52 AM
SOHC_MShue's Avatar
Default Re: question about AFC's (Dave H)
Yep I stay away from afcs like the plague. Nothing but trouble there.
slowsleeper
Engine Management and Tuning
Jun 8, 2011 07:00 AM
champwhiteEG6
Jul 10, 2009 07:52 AM
i.
Feb 12, 2009 11:50 AM
Racergurlie
Jul 29, 2003 02:49 PM
BlueSi2k
Nov 18, 2002 01:31 PM
