idle issues
Old Oct 19, 2008 | 07:33 AM
DelSolMarine's Avatar
Default idle issues
i have a built gsr turbo setup. my car was tuned and everything was running fine and for some reason it just started with the idle getting messed up. it still drives fine (a little leaner than before) but when its idling the car a/f is around 16.5-17 and if i hold the switch to make the windows go up and down it goes back to 14.5-15 and as soon as i let off it goes back to 17 again. this seems like some kind of electrical issue. has anyone seen this before? what can i do to fix this?
Old Oct 19, 2008 | 04:31 PM
mtber's Avatar
Default Re: idle issues (DelSolMarine)
Take the car back to your tuner & have him review the issue.
Old Oct 19, 2008 | 04:39 PM
NJIN BUILDR's Avatar
Do a quick check of your grounds and voltage.Your battery maybe down a cell and the alternator can't keep up at idle.Low voltage will drive you nuts.
Old Oct 20, 2008 | 03:32 PM
Default Re: idle issues (NJIN BUILDR)
i am running neptune rtp on my gsr turbo.... what should the eld gauge be reading?
Bonestock98GS
Feb 6, 2015 01:58 PM
DelSolMarine
Oct 20, 2008 03:45 PM
ShortbusEK
Engine Management and Tuning
Aug 25, 2008 08:17 PM
ThaCivicAssassin
Nov 30, 2006 01:55 PM
97EXB18C
16
Jul 22, 2004 05:27 AM
