ecu socketing help
Old Sep 24, 2008 | 01:09 PM
dx2sicrx's Avatar
Default ecu socketing help
i read the write up here on ht and it was great. but it says under the desoldering areas to remove j12. the question is, do i remove it and not replace it with anything or does another resistor go in its place?
Old Sep 25, 2008 | 05:06 AM
mtber's Avatar
Default Re: ecu socketing help (dx2sicrx)
When removing j12 you do not replace it with anything, you simply cut it out or desolder it.
Old Sep 25, 2008 | 11:09 AM
zccr-xsi's Avatar
are u going to be rtp or datalogging?if not u can just leave it in it wont effect anything.
Old Sep 25, 2008 | 11:50 AM
98vtec's Avatar
moderator emeritus
Default Re: (zccr-xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">are u going to be rtp or datalogging?if not u can just leave it in it wont effect anything.</TD></TR></TABLE>
yep, it basically unlocks/locks the ecu data.
Old Sep 25, 2008 | 07:16 PM
93turbo16's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
yep, it basically unlocks/locks the ecu data.</TD></TR></TABLE>
It doesn't really lock the data.
You can log with J12 still in tact. But it is slower.
Old Sep 26, 2008 | 03:58 AM
98vtec's Avatar
moderator emeritus
Default Re: (93turbo16)
ive never even been able to connect to the ecu to datalog with it connected..
which ems are you referring to?
Old Sep 26, 2008 | 05:44 AM
d112crzy's Avatar
Ditto. Crome doesn't let me log with j12 intact.
I think Uber is the only software that let you do that.
Old Sep 26, 2008 | 06:29 AM
ef92b's Avatar
Default Re: (d112crzy)
J12 in = half duplex
J12 out = full duplex
Old Sep 26, 2008 | 06:34 AM
98vtec's Avatar
moderator emeritus
Default Re: (ef92b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef92b &raquo;</TD></TR><TR><TD CLASS="quote">J12 in = half duplex
J12 out = full duplex</TD></TR></TABLE>
good to know. Never tried it with ectune but it wouldnt let me do anything with j12 intact when i ran crome.
turboteg90
Sep 10, 2007 05:15 AM
ej2civic
Jun 18, 2007 07:32 AM
renton
Honda Civic (2006 - 2015)
10
May 30, 2007 03:51 PM
93civciv
Apr 7, 2005 07:40 AM
phatrick2332
May 7, 2004 07:23 PM
