auto ecu question
Old Oct 18, 2008 | 05:59 PM
chinochanginc's Avatar
Default auto ecu question
I have a 94 civic lx sedan auto. I'm a noob to ecu tuning. I know that the 5-speed p06 is chippable; but is the auto version chippable? if so, what tuning software supports auto ecu's ?
thanks
Old Oct 19, 2008 | 12:32 PM
mtber's Avatar
Default Re: auto ecu question (chinochanginc)
You will have to use a custom jumper harness with an external transmission control module. Hondata works for 5 speed vehicles only.
I have never personally attempted the task using crome, ectune, neptune etc...
Old Oct 19, 2008 | 08:49 PM
Default Re: auto ecu question (mtber)
thanks
Old Oct 20, 2008 | 11:38 AM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">You will have to use a custom jumper harness with an external transmission control module. Hondata works for 5 speed vehicles only.
I have never personally attempted the task using crome, ectune, neptune etc...</TD></TR></TABLE>
Actually with the D-series, there is not TCM for his setup. All of the functions but four are controlled by linkages. You can use (I have done it on crome and Hondata) auto setups, but the shifting is sometimes sluggish/aggresive depending on the car/setup. It works...but it's not perfect.
Old Oct 20, 2008 | 12:56 PM
mtber's Avatar
Default Re: auto ecu question (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">
Actually with the D-series, there is not TCM for his setup. All of the functions but four are controlled by linkages. You can use (I have done it on crome and Hondata) auto setups, but the shifting is sometimes sluggish/aggresive depending on the car/setup. It works...but it's not perfect.</TD></TR></TABLE>
Interesting, Dseries auto ftw
balbowskie
Engine Management and Tuning
Jan 27, 2013 04:15 PM
teg01type-r
Jan 3, 2007 03:20 AM
redlineintegra
Mar 8, 2004 06:31 PM
leadtrum
Aug 3, 2002 02:35 PM
