OBDO TUNING OPTIONS
Old Oct 3, 2008 | 02:48 PM
dschenke's Avatar
Default OBDO TUNING OPTIONS
i need help on choosin i got a newly built engine and while im taking it through the break i process im a run obdo buz im a be saving up for obd1 conversion and hondata and all that ****
i havent really hurd good things bout vafc
but what other options are there?
thanks for your help
-daniel
Old Oct 4, 2008 | 05:06 PM
dephtone's Avatar
If you can find someone that can go turbo-edit or endyne I believe is obd-0 also.
Old Oct 4, 2008 | 09:20 PM
downest's Avatar
Default Re: (dephtone)
I've used both BRE and TurboEdit...
BRE is much better, IMHO. If you want to spend a little more coin try and find a ZDyne SECU.
edit: oops hit submit too fast. Make sure you can find a tuner in your area who deals with OBD0, I know it can be hard these days because nobody has experience with it. Personally I won't touch customer cars on OBD0 unless it's ZDyne, but generally they are so few and far between it doens't matter. Upgrade to OBD1, you'll only cry once.
Old Oct 4, 2008 | 09:54 PM
blakkvtec's Avatar
Default Re: (downest)
I tuned with BRE before going to OBD1. Was easy/datalogging was also inside the program. Go to pgmfi.org to get it. Easyer than turbo-edit and Ghettodyne.
Old Oct 6, 2008 | 05:03 PM
dschenke's Avatar
Default Re: (blakkvtec)
thanks for the help guys i appreciate it
i mite try out bre
Yuta
Jul 19, 2018 09:00 PM
CRXBOI239
Sep 5, 2010 10:22 AM
blaak-crx
11
Sep 10, 2009 11:51 AM
epren
Jul 26, 2005 01:08 PM
sCeRaXn
Jan 12, 2003 08:49 AM
