dataloging
Old Sep 11, 2008 | 04:32 PM
1993-eg1's Avatar
Default dataloging
Sorry for the noob question, but that is what I am I read though the FAQ and searched for it. I have a p28 and i want the datalog, what are my options and what can i use for software?
Old Sep 11, 2008 | 04:42 PM
mtber's Avatar
Default Re: dataloging (1993-eg1)
1. Is your ecu chipped/socketed ?
2. What software is your ecu's map made on ?
3. Do you own a datalogging interface cable ?
4. Do you own a wideband oxygen sensor ? If not, you should get one.
Old Sep 11, 2008 | 04:45 PM
HRTuning's Avatar
NepTune, eCtune, Hondata, Crome. You can datalog with all of these softwares or get FreeLog to use with Crome.
You can also get the TunerView LCD display for any of these softwares as well which will show you real-time data without needing the laptop.
Old Sep 11, 2008 | 04:51 PM
1993-eg1's Avatar
Default Re: dataloging (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">1. Is your ecu chipped/socketed ?
1 no (does it need to be)
2 honda's i gess
3 no
4 yes
Old Sep 11, 2008 | 06:53 PM
jdm inc's Avatar
you need one of the engine management system that HR Tuning mentioned.
Old Sep 12, 2008 | 04:17 AM
GhostAccord's Avatar
Default Re: dataloging (jdm inc)
He's going to need more than software.
1. You need a Chipped ECU - Visit one of these sites and read up on what a chipped ECU is and what you need. Moates.net, Xenocron.com, phearable.net
2. You will need software as mentioned above NepTune, eCtune, Crome, SManage.
3. You will also require an interface cable ie. the Moates Hulog
4. What wide band Oxygen Sensor did you buy? Innovate, PLX, NGK......
Old Sep 12, 2008 | 03:08 PM
1993-eg1's Avatar
Default Re: dataloging (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">He's going to need more than software.
4. What wide band Oxygen Sensor did you buy? Innovate, PLX, NGK......</TD></TR></TABLE>
1 me and one of my geeky frands from school wont to try to do this i have found some info on doing this here http://www.synoptic-tuning.com...u.htm
2 i have crome and plan on using EcuControl for dataloging
3 i plan on using hondalog to interface it
4 innovate lm1
I no that i need a eprom programmer but the diy i have on doing this douse not say what eproms that i can use i was hoping that some one might no
boostedb18kid
Oct 24, 2007 07:33 PM
Car Tweaker
Sep 29, 2007 03:11 PM
Hulk22
Oct 19, 2005 06:44 PM
ebp 99 si
Mar 18, 2004 12:33 PM
