AEM EMS vtec question...
Old Oct 13, 2008 | 07:34 PM
Mr.Burner's Avatar
Default AEM EMS vtec question...
Application: 30-1002 NSX NA1 box
Problem: No vtec to rear bank head
What Ive done:
Energized both solenoids with direct 12vts. solenoids click...
Cycling the key on and off, you can hear/feel the front bank ONLY click...
Front does nothing...
Checked for 12vts at the ecu pins D17 and D9 (vtc sol.) @ VTEC CHANGE OVER, only one pin is 12vts....
Do I have a bad ecu?
Old Oct 15, 2008 | 01:25 AM
wHOAlly's Avatar
Default Re: AEM EMS vtec question... (Mr.Burner)
do u have the sub harness for the 2nd solenoid?
Old Oct 15, 2008 | 03:52 PM
Jared's Avatar
Default Re: AEM EMS vtec question... (wHOAlly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHOAlly &raquo;</TD></TR><TR><TD CLASS="quote">do u have the sub harness for the 2nd solenoid?</TD></TR></TABLE>
from the 1002 manual, "We have supplied an expansion harness to connect to this plug which you must attach to your factory harness. To do this you plug the Yellow wire into pin D7 and the Yellow/Blue wire into A19 on the factory chassis loom (see diagram).
There should not be any wire in place in these slots. Attaching this sub harness does not prevent you from putting the factory ECU back into the car. Just use the normal VTEC plug on the factory ECU if you do."
Old Oct 25, 2008 | 05:29 PM
Mr.Burner's Avatar
yes we have all that........
main problem was...no voltage out of A19
We bought a new AEM and problem is solved. thanks guys.
carlossolorzano
Aug 26, 2010 09:37 PM
scrooge
Honda Civic (2001 - 2005)
Oct 13, 2009 07:42 PM
Perkul8r
May 14, 2009 09:14 PM
projecthonda
Feb 23, 2007 06:48 PM
Mr. Roboto
Dec 10, 2006 06:59 PM
