b16 tuning
Old Oct 8, 2008 | 04:53 PM
crxnatic's Avatar
Default b16 tuning
how can i tune my b16a obdo ??? can i get a aftermarket computer ????
Old Oct 8, 2008 | 06:53 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: b16 tuning (crxnatic)
Well you can modify to obd1 or stay obd0 and both offer tuning.
Turboedit and zdyne are the only 2 that still do OBD0 as far as I know, other then custom maps on your ECU.
Old Oct 9, 2008 | 02:24 AM
davidu's Avatar
you can also try xenocron.com and moates.net
im in the middle of dealing with this on my obd0, xenocron doesnt advertise that they will but i talked to a very helpful guy on the phone and for $65 they take your ecu, desolder your chip out, resolder a new zifsocket and give you a chip with a stock basemap.
that gives you a place to start, from there you can either tune from your computer off the car with a chip burner or you can get an "ostrich" or similar system to tune in real time on a dyno (or ghetto *** street tune)
Old Oct 9, 2008 | 06:41 PM
crxnatic's Avatar
Default Re: (davidu)
on the zdyne system they have a super ecu for like $565 you send them your ecu and they coverted it you can tune it up on computer you can basically change everythig it has vtec controller do you think is worth it??????
Old Oct 9, 2008 | 07:13 PM
redbarchetta's Avatar
You can stay OBD0, get the ecu chipped or DIY. BRE is a nice program to tune with.
http://ef-honda.com/ben/bre/maindoc/index.html
Old Oct 9, 2008 | 07:34 PM
crxnatic's Avatar
Default Re: b16 tuning (redbarchetta)
which chip do you recommend because the zdyne is a tuneable chip. what chip do you recommend that is not that expensive but it is badass i want something that i will be able to plug on the computer and tune it myself
Old Oct 9, 2008 | 08:15 PM
zrickety's Avatar
i was told that the ostrich requires the laptop to operate even after you program it...that would suck if it's true. anybody know?
Old Oct 10, 2008 | 08:43 AM
Just contact Xenocron about having him install the chip and a zif socket. They are all programmable. As davidu said, you'll need a chip burner to flash the chip with a new program or the ostrich from moates.net
http://www.xenocron.com/catalog/services.php
The ostrich does not require a laptop to operate, only to upload a new map to it.
Old Oct 18, 2008 | 09:12 PM
dirtragz's Avatar
get your pr3 ecu chiped and you can tune it isnt as easy as obd1 but alot cheaper mine is chiped that way
mrpaccmann
Engine Management and Tuning
Apr 15, 2010 03:58 PM
itr1244
Jun 9, 2009 11:17 AM
EF-8SiR
Jan 28, 2009 06:18 AM
gsrpowercrx
Nov 9, 2008 06:54 PM
allnaturalb16
May 5, 2007 11:01 AM
