tuning question
Old Oct 6, 2008 | 04:37 AM
02vtecsir's Avatar
Default tuning question
i have an ecu done from phearable and i am changing my motor set-up due to possible sales of the car
i had
Jdm B18c Type r fully built head with JUN stage 4 cams
11:5:1 compression supertech pistons 81.5
eafle rods stock crank
rc 310 injectors
skunk 2 intake mani
CAI
spoon head gasket
4-1 semi-race header
fullt titanium race exhaust and race cat
pulleys
aem fuel rail
adjustable fuel pressure reg
and more little things
all running on a p28 w/ S200
i am now changinh out the cams back to stock CTR's
i sent him all the specs for the engine with CTR's and keeping the same compression, can i use this ecueven with the slight bump in compression still
Old Oct 6, 2008 | 05:17 AM
mtber's Avatar
Default Re: tuning question (02vtecsir)
Can you clarify what you are trying to ask ?
You are running a set of jun4 cams now, however you ordered a program for ctr cams & want to run the car on the jun 4 cams with the ctr cam basemap ?
Old Oct 6, 2008 | 07:50 AM
HRTuning's Avatar
Default Re: tuning question (mtber)
Almost sounds like it was setup for the Jun 4s and he's downgrading to CTRs, in which case it'll run rich. If it was just a basemap to begin with, you'll probably need it tuned anyway because it wouldn't be perfect.
Old Oct 8, 2008 | 08:11 AM
02vtecsir's Avatar
problem solved i am keeping the JUN stage 4's in it, just got orders to okinawa japan so this car goes in storage till i get back with goodies
saemoonyang
28
Sep 14, 2011 10:02 AM
02vtecsir
Oct 10, 2008 07:48 AM
aziantegger10
Oct 16, 2005 07:36 PM
jdmGSR.fo0!
Jul 8, 2005 09:23 PM
allmtr
Apr 22, 2003 07:54 PM
