Which ecu????
Old Oct 5, 2008 | 12:11 PM
connor53's Avatar
Default Which ecu????
ok i have a 99 civic ex with a Jdm b18c sir-g engine swap... right now i have the p72 obd2a ecu and im looking into buying a obd1 ecu for tuning purposes...what is the best obd1 ecu i should get for my set up and if it matters im planning on running a hondata s300 as well?
Old Oct 5, 2008 | 12:49 PM
azeez's Avatar
Default Re: Which ecu???? (connor53)
you can use P30-a, P28, P72 with hondata s300
Old Oct 5, 2008 | 02:15 PM
mtber's Avatar
Default Re: Which ecu???? (azeez)
You can use a variation of obd1 ecus. Since your running an obd2 vehicle, you will need an obd2 to obd1 jumper harness or a hondata s300 obd2 bundle package which allows you to plug & play an obd1 hondata s300 ecu into your obd2 vehicle.
We are an authorized honda-tech sponsor & hondata dealer, feel free to check us out at http://www.phearable.net
civicsi18
Nov 10, 2008 04:33 AM
01_ITR
Jul 8, 2008 04:40 PM
mitchell_2kSiR
Dec 30, 2007 09:32 AM
otakueric
10
May 22, 2004 06:07 PM
yellowbuffalo
Jun 2, 2003 06:24 PM
